Question about Aprilaire 600 Humidifier
Aprilaire 550 humidfier not getting water - Aprilaire 600 Humidifier
  • 3 Answers
Is there 24 volts coming from the humidastat to the solinoid?
Posted on Dec 08, 2008
Fan and water does not work
What brand and model do you have for starts. Sounds like a low voltage power issue.
Feb 24, 2015 | Aprilaire 700 Humidifier
How do I shut the water off to my Aprilaire 550
Hi follow the water line from the water valve back to the cold inlet pipe should be a tap on there
Jan 21, 2010 | Aprilaire 550 Humidifier
Low or no humidity.
i have an aprilaire model 550 im getting no water to the filter but i am getting water to the solenoid
May 11, 2009 | Aprilaire 550 Humidifier
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
My humidfier is not working
is the water on ? if it is you will need to use a multimeter to test to see if you have 120 volts at the transformer, 24 volts from the transformer to the solenoid, make sure you have the low voltage wiring completing a circuit from the transformer, to the solenoid, from the solenoid to the humidistat, humidistat to the transformer again, make sure your transformer is hooked in to only receive power when you are calling for heat, thats about it, hope that helped ya, and thanks for your question, let us know if that helped, thanks again,
mr.grzz
Jan 20, 2009 | Aprilaire 550 Humidifier
Routing waterline to pad
1/4" flexible copper pipe. Tap into your cold water line using the included saddle valve (pierces the pipe), attach the 1/4" flexible copper pipe to the saddle valve on the cold water pipe and the solenoid valve on humidifier unit using the included compression fittings. Tada!
Dec 10, 2008 | Aprilaire 550 Humidifier
No water flow to the humidifier
Turn that pin to the left and that will open the valve to allow water to flow through it. If it starts to leak the all you need to do is tighten the nut that were the water is coming out with a wrench, be carefull it wont take much to tighten.
Dec 02, 2008 | Aprilaire 600 Humidifier
Aprilaire 550 humidifier
Did you clean the orfice ? It is located on bottom of solenoid. It is plastic with a very small hole.The hole gets plugged and you can clean it or buy a nw one for 50 cents.
rdsvideo2@yahoo.com
Oct 18, 2008 | Aprilaire 550 Humidifier
Aprilaire 600 Humidifier Logo
79 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
