Question about Samsung HLR5667W 56" Rear Projection HDTV
Tv comes on but screen is black
I turn tv on and the lamp comes on and turns off but does not make turn on sound or the screen does not change
  • pimpballer Jan 11, 2009
    nothing will happen with my tv, wont turn on or off or switch anything
  • 505 Answers
You likely have a problem on your digital main pcb. This is the computer board that will process all the picture plus makes the power on noise.. if its a 5667wx then your part is BP94-01859F BOARD, MISC-DIGITAL
try unplugging the tv for two minutes. in rare cases this hard boot will reset and fix
Posted on Dec 07, 2008
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
I turn the tv on and the sound comes on but the screen stays black. Everything is plugged in correctly and all the settings have not been touched.
The LED indication light on the front screen bazel panel said "LAMP" light up or flashes?This tv the projection lamp been in use like 4 or 5 hours a day of watching tv,the lamp been in the tv use like a 1 1/2 or 2 years inside the tv in use?The Lamp life is over,the lamp reqiure changing.
Jun 24, 2010 | Hitachi 43FDX01B TV
Our Hitachi tv turns on okay but the picture on comes in for 2-3 seconds and then the screen goes black. Last night the tv work just fine but this problem started today as I turned the tv on to watch...
I don't know what model you have,but... I have a 50v715 and it was doing the same thing and it turned out to be the lamp. So if you have not replaced the lamp in a while then it could just be it time. Hope this is helpful.
Oct 03, 2009 | Hitachi Televison & Video
Screen is black two green blinking lights 1 red
Ur power supply needed to be rebuild,like changing capacitors,extra..Or buy a new power board,because it dead.
Sep 13, 2009 | Samsung DLP HL-P5663W 56" TV
I turn on the tv but I get no picture (black screen). A sound starts when I turn on the tv. The sound ( like a humming noise) fan perhaps which goes up and down for about a minute then the tv shuts off and...
Sounds like a problem with the color wheel. Unfortunately the color wheel is located inside the light engine. According to everything I have read, the only thing you can do is replace the light engine. You are better off replacing the TV. The light engines can run form $750 to $1400. Which is ridiculous!
Jan 02, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
SCREEN IS BLACK
Called a service tech, (for free)
he said it was probably the lamp, and it was an easy fix.
Just have to order the lamp and put it in our selves.
I will let you know if it works or not.
We were told the lamp goes out anywhere between 1000 - 2000 hours.
So we will be needing the lamp regardless.
Sep 26, 2008 | Mitsubishi WD-57732 Projection Television
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony kf-60we610 screen in black and white
Hi there
Is this a DLP tv ?
If it is then your colourwheel might need replacement
Mar 18, 2008 | Sony XL-2100U Projector Lamp for...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung HLR5667W 56" Rear Projection HDTV Logo
261 people viewed this question
Henry  Thomas
Henry Thomas
