Question about Orion1934 19" TV
I have cable tv with comcast and i had to change tv brand is orion and I cant get comcast remote to work the volume control or turn off the tv.
  • Orion Master
  • 5,568 Answers
You need to go to the Comcast website, since it is their remote, and check the code listing to learn if your new set is even supported; they often aren't.
Posted on Dec 07, 2008
Comcast put in a new hd box and now we cant get the remote to work to change the channel we have to trun off at tv on the side
I'm assuming you got a new remote with the cable/sat box. These remotes can act as universal remotes but must have a code input that will operate your particular brand of TV. This should allow for turning the TV on and off and controlling the volume if you are using the TV speakers. You should also check that the correct button has been pushed on the remote to operate the channel selection on your cable/sat box. There should have been a user manual given to you with the new cable/sat box that will detail the process for finding and inputting the code and other troubleshooting. You may also find answers on the cable/sat provider's website. Good luck.
Aug 14, 2015 | Vizio Vizo VP503 50-inch Plasma HD...
I have comcast cable and an insignia tv. I am try...
If you're in need of remote control codes, a variety can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 21, 2010 | Sony RMT-D153A Remote Control
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
13" superscan remote with comcast
all cable networks have a manual that shows how to us the R/C [remote control] to SCAN ALL model #s of tvs for all the codes. If you don't have the manual, call Comsast Cable & they should be able to help you.
Note: sometimes a cable network cannot control all TV's R/C because some companies BUY off excess tvs and place their name on the brand.You could be buying Zenith, Sony, RCA !! guts with E.I. "superscan" brand on it.
P.S. sometimes the code is just enought to turn the tv on, raise\lower volume.
Jun 24, 2008 | Televison & Video
ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Jan 22, 2008 | Orion1934 19" TV
Trying to set my Directv remote to control my Orion TV........
Orion code is 11911 and to program your tv to work with a directv remote then follow these...
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Slide the "Mode Switch" back to Directv and try adjusting volume and turning tv and receiver off using the off button and then back on with the on button just above the off button
  • Dec 28, 2007 | Orion1934 19" TV
    Jumbo Universal Remote
    I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
    Dec 26, 2007 | Universal Remote Control NspireGear MP3...
    DTV remote code
    KZXten,
    Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
    1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
    2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
    I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
    Here's a link to the remotes Comcast is providing in my area.
    http://www.comcast.com/corporate/customers/customer_support/remotes.html
    Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
    Remote control code needed for this TV
    Need to program my Insignia TV to my Direct TV remote. Need code
    Nov 07, 2007 | Insignia IS 20" TV040919 TV
    Orion1934 19" TV Logo
    97 people viewed this question
    Top Orion Televison & Video Experts
    wayne chamberlain
    Jerry Greenberg
    Jerry Greenberg
    Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
