Question about Troy Bilt Backpack Blower, 25cc, 160 Mph, 500 Cfm, Model No. Tb25bp
Blower wont run at full throttle
I have a troy bilt 25cc backpack blower. It runs fine at idle, but as soon as I try to increase the throttle, it bogs the engine down. If I try full throttle, it will conk out.
  • 3 more comments
  • Anonymous Jan 25, 2009
    I have the same problem.. I do not have the solution.
    Mine conks out!
  • Anonymous Mar 30, 2014
    Blower will idle fine but cut out if try to throttle on
    Full throttle it wants to stall
    Full throttle juSt bogs down
  • 68 Answers
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Posted on Dec 11, 2008
I have a craftsman 185 mph/ 25 cc blower. I finally got it started and running, but when i move from half choke to run it begins to shut off. I'm kind of thinking its a dirty carb,not a fuel problem. I need to know how to clean the carb though. This little lady doesn't have a whole lot of work with small engines, but it needs to be done. Thanks for the help when/ if I get it.
Posted on Dec 16, 2009
Try 40:1. Better to have too much oil than too little. If you find the exact ratio then use that. ...Lee
Mar 12, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
What is the mix ratio for the troybilt 25cc blower?
Troy-Bilt products now are usually produced by Mtd, the ratio being 40:1.
However since John Deere made yours I'm 99.9% sure it should by 32:1.
In any case any power equipment you own (including Dolmar or Stihl) that takes an oill/gas mix benefits in the long run from using the richer 32:1 ratio. It protects the piston and cylinder much better, giving your equipment longer life. Do not use the "one mix for all" that you find at retail stores as it has been my experience it really isn't "one mix for all". Seen a lot of scratched pistons and broken rings from people using that.
Jun 17, 2009 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(, to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Nov 15, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Troy Bilt Backpack Blower, 25cc, 160 Mph, 500 Cfm, Model No. Tb25bp Logo
3,583 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
