Question about Intuit QuickBooks Pro 2008: Windows
Quickbooks Pro 2008 will not load
I have had this program for months and it has run fine then all of a sudden when icon is clicked it will not load
The issue is with a corupted 2.0.net framework file.
Solution: start>type cmd>right click and hit run as administrator. type: "sfc /scannow " and hit enter.
may prompt for windows dvd. that will fix it.
Posted on Apr 05, 2011
  • 32 Answers
Have you tried repairing the program? Go to control panel, add/remove programs. Scroll down to Quickbooks, click on remove. It will give you the option to remove or repair. You might need to have your CD hand in case it prompts you for it.
Posted on Feb 06, 2009
Quickbooks pro desk top icon dissappears
This usually indicates that Windows is damaged. You can reinstall the software, then go to the program files folder, Intuit, Quickbooks 2008 and run the file called Reboot.
Jun 22, 2012 | Intuit QuickBooks Pro 2008: Windows
I have QuickBooks Pro 2008. When I'm starting the program it gets as far as asking for the password, then that's it, the program never actually starts up. The icon is displayed in the active task...
Try using Alt+TAB to see if it is actually there, but pushed off the screen.
You may need to reinstall the software to get it to fully work correctly.
You can also right click the task bar on the bottom and choose Windows, Cascade.
Oct 05, 2011 | Intuit QuickBooks Pro 2008: Windows
Recently purchased a new computer with window 7. Ouickbooks 2008 installed ok but within a week I got the message a file within the program should be replaced. I tried to uninstall QB 2008 but it will not...
Welcome to Fixya
To uninstall the QB 2008 program. Click start menu then click control panel. Go to program and features icon and search the quickbooks 2008 program. Highlight it and click uninstall on top. Wait until the program will be uninstalled to your system.
Thank you for using FIxya!
Sep 04, 2011 | Intuit QuickBooks Pro 2008: Windows
Cannot open Quik Books 2007
Windows XP:
  1. Uninstall QuickBooks, Microsoft .NET Framework, and Microsoft Visual C++ 2005 Redistributable:
    1. Close QuickBooks.
    2. Click the Windows Start button and select Run.
    3. Enter control in the Open field and click OK.
    4. Double-click Add or Remove Programs.
    5. Right-click your QuickBooks program version and click Change/Remove.
    6. Follow the instructions to Uninstall QuickBooks.
    7. Repeat steps d through f to uninstall Microsoft Visual C++ 2005 Redistributable.
    8. Repeat steps d through f to uninstall Microsoft .NET Framework for your version of QuickBooks:
      • QuickBooks 2008 and 8.0 and later:Microsoft .NET Framework 2.0
      • QuickBooks 2007 and 7.0 and earlier:Microsoft .NET Framework 1.1
  2. Rename the QuickBooks program folder:
    1. Right-click the Windows Start button and select Explore.
    2. Browse to C:\Program Files\Intuit.
    3. Right-click the QuickBooks folder for the version you just uninstalled (for example, QuickBooks 2008) and select Rename.
    4. Enter OLD_ at the beginning of the folder name and press Enter (for example, OLD_QuickBooks2008).
  3. Insert the QuickBooks CD in your CD drive, and follow the instructions to install the program.
  4. Open QuickBooks.
Jul 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks 2008 will not load, it says that it is installing and then goes to error 1325
Assuming you have Win XP, please follow these steps:
1. Remove QB from Control Panel>Add/remove programs.
2. First rename all folders of Intuit. rename Intuit to Intuit-old from the following locations.
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then disable your Antivirus / Online Security.
4. Then install quickbooks using quickbooks.msi . You will find quickbooks.msi in the foll location:
>right click on ur QB disc and click open/explore.
>Double click on QBooks folder and run quickbooks.msi and follow the wizard.
If you still get any more issues, please reply with following:
1. Which windows version you are using ?
2. Are you installing QB for the 1st time on this computer?
3. Did you install any other software rrecently ?
P.S : this issue may also be because of Microsoft .NET framework on your computer. PLease help me with your reply to help you.
Feb 19, 2009 | Intuit QuickBooks Pro 2008: Windows
I am using quickbooks premiere edition 2008 and when I try to do anything with adobe reader it fails. I really need to get reader working
Try uninstalling the Quickbooks PDF converter.
Open the printers folder:
  1. In Windows XP: Double-click Printers and Faxes.
  2. In Windows Vista: Under Hardware and Sound, click Printer.
  3. Right-click the icon for the QuickBooks PDF Converter and choose Delete.
    1. Open the printers folder:
    2. In Windows XP: Double-click Printers and Faxes.
    • In Windows Vista: Under Hardware and Sound, click Printer.
    1. Right-click the icon for the QuickBooks PDF Converter and choose Delete.
    Jan 29, 2009 | Intuit QuickBooks Pro 2008: Windows
    Went to open Quickbooks pro 2008 and received an error code of 80029c4a. It also said there was an error loading type library/DLL. Any solutions? Thanks
    Update your Quickbooks, run reboot.bat, restart your computer and then restart Quickbooks
    1. Open the folder containing the reboot.bat file:
    2. Windows Vista: Right-click the QuickBooks icon on your desktop and select Open file location.
    • Window XP:
      1. Right-click the QuickBooks icon on your desktop and select Properties.
      2. Click Find Target.
    1. Double-click the reboot.bat file
    Jan 06, 2009 | Intuit QuickBooks Pro 2008: Windows
    Quickbooks Pro-restoring a back up from a previous version 2005
    If is any help - we have just had the same problem.......had version 5 (very old) of QB
    changed computer to Vista and would not work so had to buy Pro 208 for Vista . We really had to get in touch with Quickbooks - they send you a free upgrade kit (disc which is Pro 2006 version (not a fuull version but enogh to get the data over) then you load that on your old machine transfer your data to that then copy that again - then load into Pro 2008 - worked fine for us - have come across a hiccup with VAT - but however I guess we are going to have to give in and phone them after the Bank holiday........apart from that everything was fine.
    be brave and phone 'em - tech support was helpful.
    May 05, 2008 | Intuit QuickBooks Pro 2008: Windows
    Ran SpyBot to fix lag issues, now can't access my Quickbooks 08
    Spybot has been known to damage the QuickBooks program in the past.
    You will need to reinstall the program.
    Apr 15, 2008 | Intuit QuickBooks Premier 2008 (3-User...
    Intuit QuickBooks Pro 2008: Windows Logo
    507 people viewed this question
    Top Intuit Computers & Internet Experts
    Alun Cox
    Chris Larocque
    Dan Shibata
    Dan Shibata
    Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
