Question about Microwave Ovens
Whirlpool Gold microwave doesn't heat
I have an ''in cabinet'' or ''non-countertop'' Whirlpool Gold microwave GT4175spsz that is about 18 months old and no longer works. The clock, timer etc. all work, but once I hit start, the light comes on, countdown begins, but it doesn't heat up, or make the noise when something is being heated. I called customer service and they said I was out of luck since I only had a one year warranty. Is this fixable or am I just better off buying a new one?
Thanks in advance for any answers or advice.
  • Microwave Ovens Master
  • 9,086 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Dec 07, 2008
My microwave oven buzzes when plugged in
Normal it buzz when you left yo food inside even its fin7shing warming or wateva youre doing, but if its just buzz you can disconect it if you want or take it to the technician
Sep 17, 2014 | Magic Chef Microwave Ovens
Whirlpool gold microwave model gh6208xrs stopped heating
As a service tech do not attempt to service a MW call a professional or replace there are components within that raise voltage from 120VAC to upwards of 5000VDC leave it alone call a pro
Sep 02, 2014 | Whirlpool Microwave Ovens
My whirlpool gold GT4185SKQ-2 microwave won't heat
It's not door switch. It's the microwaves are not being produced. Do to safety issues DO NOT take apart. Replace
Jul 24, 2014 | Whirlpool Microwave Ovens
I HAVE A ACCUWAVE WHIRLPOOL GOLD BUILT IN MICROWAVE THAT RUNS BUT IS STILL NOT HEATING. HOW DO I FIX THIS?
This is not a simple solution, the magnetron the heart of the system may be defective, or the inverter board, "7 years old or less" and possibily the keypad control board, you will somebody that can use test equipment.
May 04, 2012 | Whirlpool Microwave Ovens
It is only about 11 months old and the turn table moves and it sounds like it is working, but it is not heating. it is a GE countertop model. If it is a circuit board will it cost more to repair than to...
If it is running and not heating the problem will most likely be in the heating element which is called a 'magnetron' before you throw this away check with your owners manual, most of these have a 1 year warranty on the microwave.
Apr 20, 2010 | GE Microwave Ovens
Whirlpool gold accuwave system above the range microwave
Small "d" indicates door. One or more of the door switches is not closing properly or have failed. Anything from a misaligned door to faulty components...Eric
Aug 07, 2009 | Whirlpool MH7140XF Microwave Oven
MICROWAVE WILL NOT HEAT
In my case I found an additional fuse, a high tension fuse (5KV 0.8A) in a white on-line isolation slave next to the transformer.
The fuse was blown.
I guess replacing it should solve the problem.
Oct 07, 2008 | Microwave Ovens
Microwave Ovens Logo
115 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
