Flyback blew Is this something I can fix myself
  • chuckjenkins Dec 07, 2008
    so does that mean I would have to buy a flyback and a deflection board? How much does all that run just for parts?
  • 505 Answers
Not likely. I would attempt to get a deflection board to fix the problem.
Posted on Dec 07, 2008
I have a panasonic chassis ct27hl14 with a bad flyback, can i use a txfft01gser in place of the txfft01jser flyback?
Not sure, I'm having problems myself. The HOT shorted, replaced with a new one, still no HV. Did you have similar problems and it blew the flyback? I hate Panasonic for not putting values, just some part number on their capacitors, etc, so you can send it in to them. If that were the case, I should just take this TV out for target practice, as I have a flatscreen. If my board is screwed and the TXFFT01JSER is good, are you interested in it? Also, what's the B+ pin on this, I got a couple options, 4, and the one next to the HOT collector pin.
Feb 26, 2011 | Televison & Video
I have the same problem with my set. do you thin
Many of these tv have bad flyback # 265409. Also maybe the solder on flyback or fuses around of flyback
Apr 23, 2010 | RCA D61W20 61" Rear Projection Television
RCA 32V550T Nothing happens when you press Power. NOTHING.
This set needs a flyback transformer p/n 262342, and a horizontal output IC, location number on the board is q14401 and crosses to NTE2353. When you're in there too touch up any bad solder joints you can find. Fixed several of these with the same problem.
May 25, 2009 | RCA 32V550T 32" TV
Okay let me know what you think
the flyback transformer is the large black component simalar looking to a disrtibitor of a car it has a large red wire coming out of top and a black wire. On the bottom of the board it has about 10 pins arranged in a circle. this is flyback is located adjacent to the fuse.
Dec 07, 2008 | RCA HD52W59 HDTV Projection Television
BLURRY SCREEN
If all 3 colors are mis-aligned, you may have solder connections that blew a fuse. There are three fuses next to the flyback transformer, one usually blows causing this issue. Resolder the flyback solder connections and replace the fuse to fix.
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W19 Screen Flicker
Go back to FBT check and make sure your high voltage wirer is in good.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Angiephox
yes the flyback is inside the TV, and yes I can post a link where you can get a new replacement for around 50 dollars and it comes with free on line tech support so you can do the job yourself. Its a job that only requires basic soldering skills. If you would like the link let me know
May 13, 2008 | RCA P52926 52" Rear Projection Television
RCA P46921. Just changed flyback.
if nothing has been tampered with ie. focus controls, lens focus, I would check to make sure the high voltage lead is seated correctly.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
Loewe Aconda 9383-S TV
flyback transformer...get a pro to fix it
Jan 27, 2008 | Loewe Aconda ACO9303 30" TV
TV repairman blew fuses??
yes maybe ...but he made problems alot worse bypassing your fuse, the fuse is there to blow if you have a short and not harm other components. my guess is that he damaged your power supply and then fixing that youll still have the orginal problem. I think I was the only tech in Houston that could troubleshoot. Sad, but very few good tv men or big screen. we trained are outside guys not to touch much but do slight adjustments and bring it into shop if you dont have a clue and they make some story up to the customer. good luck
Aug 16, 2007 | Toshiba 61HX70 61" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
