Question about Hayden Industries SuperVac 3600 Central System Vacuum
Supervac never comes fully on
I have a Hayden Supervac Superior central vac system with is about 5 years old.  Never had a problem with it.  I can't find the book for it or the model number(not on front of wall tank).  When I put the hose in the wall it comes on but then goes off and keeps cycling like that.  It never makes it fully on.  Just kind of cycles on and then off.
Any ideas?
  • 547 Answers
Wireing from wall mount to vac
Posted on Feb 12, 2009
  • albert getty
    albert getty Feb 15, 2009
    this is dew to not enought power this unit need 60 amp breaker by it's self to run.
The brush on my hayden 6000 supervac is not rotating when power is on and i can't figure out how to open the vac to get to the belt. help please
First you will want to remove the light cover. this can be done by pusing as you look at the front of the powerbrush on both the left and right side of the head.
There you will find the lightbulb and 2 screws to remove. Remove both of the screws and turn over to pry with a screwdriver at both the sides of the powerbrush to remove the top cover.
Once you have the lens cover off you will also see in the plastic the belt change instructions.
When you want to put the top cover back on, it will act much like a hinge, hook it on to the front of the head where the brush is, and snap it back into place at the back.
Nov 04, 2010 | Hayden Industries SuperVac 6000 Central...
I have a Hayden SuperVac 3600, almost 10 years old. The unit still runs, but now when I switch to the power nozzle, it doesn't have power to turn that. I think this happened once before and maybe they...
The hose has fuseable link inside, generally a 3-7 amp. It is at the wall end underneath the hose cuff. Easy to replace as it crimps in line. If you have a meter you can also test the detachable hose to wall cord for continuity, then check the hose to handle as well.
You can also detach the hose to wall cord from the hose, and plug your power head directly into that cord,, then into the wall thereby eliminating the hose itself.
Hayden makes a serviceable hose. If damaged or the fuse blown it can be serviced by a good tech. If the fuse is blown you need to clean and inspect the power head as this may be the cause
Jun 20, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden SuperVac central vacuum making an unbelievably loud noise.
Stop using the vac. Remove the filter and clean thoroughly, inspecting for damage. If the vac is spiting out bits off fuzz or lint it may need the motor cleaned and serviced as dirt has leaked past the filter. If it is spewing black, not gray this is carbon dust from the motor brushes. If the noise is scratchy or growling this is a sign of a motor problem as well.
The muffler unless it is a hepa filter/muffler combination is NOT designed to catch dust.
Exhaust dust is a sign of dust leaking through the motor which indicates future moor problems.
HINT, if the guy who installed the muffler didn't secure it right he is probably not a good choice as a service tech either. The muffler is normally clamped or secured in place with a small screw so it can be removed in the event of service.
Jun 14, 2009 | Hayden Industries SuperVac 3600 Central...
Hayden 6000+ wont run
Define hose works or doesn't, no suction, hose will not activate vac , etc.
Test the vac by shorting across the low voltage terminals where they enter the machine. If the vac works here your problem is in the internal wiring, at the valve or the hose to wall connection. If the vac will not run, you will need to check the motor for continuity across the motor leads.
Apr 18, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden Super Vac Premier will not stop unless I unplug
one of two problems cause this. first is a short in the wires that turn it on, the small wires going to the side of the body unplug one of them to see if thats the problem
second is a stuck relay inside the top cofer of the main body
Jan 26, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hayden Industries SuperVac 3600 Central...
Hayden Vac2400
Check the carbon brushes, they maybe worn out and need replacing.
Jan 06, 2008 | Hayden Industries SuperVac 2400 Central...
Hayden Industries SuperVac 3600 Central System Vacuum Logo
146 people viewed this question
Top Hayden Industries Vacuums Experts
Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
