Question about Samsung RS2630SH Side by Side Refrigerator
Refrigerator door The regrigerator door will not close without pushing it firmly. THere is a piece that is broken on the bottom that helps it to draw the door closed when it is headed in that direction. I need to order that piece, how do I find out what the part number is? Samsung RS2630SH Thanks Manningfam
    Problem Solver:
  • 16 Answers
TRY ALIGHNING THE DOORS.I HAD ONE CLIENT THAT I HAD TO ALIGHN THE DOOR UPWARDS BECAUSE THE DOOR WAS TOUCHING THE BOTTTOM OF THE FRIDGE ON THE INSIDE.
Posted on Feb 23, 2007
Subzero regrigerator door not closing properly
Is it possible to elaborate a bit? Is it sticking? Jamming? Slamming? Not staying closed or sealed? Most of the time problems arise from damage to the white rubber seal (subzero's are specially fitted to ensure a stellar seal). Check along the entire rectangle surface for any cuts or problem areas.
Aug 16, 2014 | Sub-Zero 650 / O Bottom Freezer...
Why on a whirlpool gold double door refrigerator
That's an easy one, the draw is not in correctly, preventing the door to close properly. Clean up the mess then work with the draw until it seats properly, then double check that the door seals closes right.
Jul 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
My LMX289885T/02 LG refrigerator's left door will not close without manually pushing the long bar into place first.
Guessing your talking about the heater. Sometimes the sprin comes loose, in the end probably will have to change it out
Sep 08, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
How do i remove the door from a side by side ge fridge , the bottom spacer has broken in half and the door will not close without lifting it.
Don't need to remove door, just get new piece, then block door up remove hinge and replace, just be sure to keep door closed and lighten it up by removing food from it..
Jan 03, 2010 | GE Refrigerators
The fridge will close but you have to pushed
Ya do change the Plastic In Between between the Hinge and the Door .If it Doesnt work try looking at the Hinges they Might Be loose
Jul 02, 2009 | Refrigerators
Freezer door won't seal
its a visual thing inspect and look for somthing not right[ie..door seal torn,door warped.hinge cam broken.somthing in the way food package wise so door wont close.God bless,tom
Jan 01, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Hotpoint FFA70 - Freezer door will not close properly.
The rear panel can be removed,i have done it.I removed the 4 hex head screws from the top & bottom of the panel,and firmly pulled it forward.The reason i say pulled firmly is that when panel came out the back of the freezer was solid with ice.I have defrosted the freezer,dried any water from the unit and replaced the panel.Fingers crossed,so far,so good.In my case this build up of ice was definately the reason the drawers were not sitting in the correct position,as it caused the rear panel to 'bulge' out.Hope this helps.....
Dec 11, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
550 Door Seal Doesn't Seem to Be Working
Since the doors on most refrigerators are adjustable, check the alignment of the door by pushing it close to being closed and seeing if the crack still visible is consistent around the three sides not yet in contact with the frame. These normally don't change much over the life of the unit but you may be able to improve the contact through an adjustment. Considering that the door does not seem to want to stay closed, check too on the hinge side to see if that part of the gasket is striking the frame too early.
Jul 23, 2008 | Sub-Zero 650 / O Bottom Freezer...
Temp control pad does not work
if you can replace the temperature control pad then that is the answer. it is stuck open.. does not closes as the temperature of the cabinet cools down.
Nov 18, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Samsung RS2630SH Side by Side Refrigerator Logo
118 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
