Question about Lexmark Inkjet Z517 Photo Printer
Error code 50C, "printer cartridge error" in display
This is a 5100 Lexmark All in One, about 8-9 years old? Replaced black cartridge, worked perfectly, then I got this error code. Tried standard fix it per computer, and printer instructions. Also, have gotten message "printer not communicating". Tried reinstalling printer, no results.
However, I am no "wizard" maybe I am missing something.
Thanks,
Loni
  • 20 Answers
LEXMARKS ARE KINDA "FINICKY" WHEN IT COMES TO CABLES AND DRIVERS, TRY CONNECTING IT TO ANOTHER PORT ON THE BACK OF YOUR COMPUTER AND ALSO REPLACING THE DRIVERS WITH BRAND NEW ONES MAY HELP, LEX MARK SHOULD HAVE A SET UP UTILITY FROM THERE WEB SITES SUPPORT PAGE WHEN YOU BROWSE IT WRITE DOWN YOUR SERIAL NUMBER FROM UNDERSIDE OF THE PRINTER AND USE THAT WHEN YOU BROWSE THERE SITE. YOUR PINS ON THE CONNECTOR MAY BE "FRAGGED" SO DEFINATELY BEFORE YOU RE-CONNECT AT ANOTHER PORT GET ANOTHER USB CABLE THEY ARE PRETTY CHEAP AND READELY AVAILABLE AT BEST BUY AND SO FORTH, HOPE THIS HELPS JON T...
Posted on Dec 07, 2008
Yes I have an cartridge error 50C and I can't seem to fix the problem.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 30, 2010 | Lexmark X5150 All-In-One InkJet Printer
Errir 50C
Try these solutions from Lexmark online support: (apparently one of your print cartridges has shorted)
Lexmark X5150 Error 50C
Jan 09, 2010 | Lexmark X5150 All-In-One InkJet Printer
Cartridge error 50C
Hi there Error 50c
This not same dell as yours but who knows it may well work for you.
color cartridge.
Jan 04, 2010 | Lexmark X5150 All-In-One InkJet Printer
Won't print reads error code 50c
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 31, 2009 | Lexmark X6150 All-In-One InkJet Printer
Error 50c
Hi there Error 50c
Gave it a go it may work for yours.
color cartridge.
Dec 27, 2009 | Lexmark X5150 All-In-One InkJet Printer
Will not print,shows65% on screen then printer shows cartridge error 50C see user guide book which I cannot find. My printer is registered with you.
this problem is most likely a damged, defective, or offbrand cartridge. that is what the error code 50C stands for. to test my theory, get an original lexmark black and color cartridge. don't buy it unless you have to. borrow it from a friend or from work. then, clean the inside of the printer with a vaccum and (using isopropal alchol). after performing these tasks, put the new cartridge in one at a time. Make sure you have one old and one new. for example, a new black and an old color. this will tell you which cartridge is defective and needs to be replaced. then fin yorself another company that sells the cartridges and try them.
Jul 09, 2009 | Lexmark X5150 All-In-One InkJet Printer
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
color cartridge.
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
Lexmark 5150
I went to the Lexmark site and downloaded the manual. Looked for my problem 'Cartridge Error 50c' and found that my color ink was empty. It took some playing around, but that was it.
Aug 11, 2008 | Lexmark X5150 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Cartridge error 50c
I removed the color cartridge and left the black one. it worked.
(I have Lexmark X6100 Series)
Jan 17, 2007 | Lexmark X5150 All-In-One InkJet Printer
Lexmark Inkjet Z517 Photo Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
