Question about SanDisk 2GB microSD Memory Card
Where do I fit the Sandisk 1 gb card into my Blackberry 8310?
    President:
  • 1,073 Answers
Under the battery
here is andemostartor how to do it
http://demos.blackberry.com/8310/na/us/gen/
Good luck
Posted on Dec 07, 2008
What is the code to unlock the blackberry 8310 curve
Do you need to unlock your Blackberry Curve 8310 from network lock?Blackberry has 10 unlocking tries..So you have 4 remaining unlocking tries.You can get the unlock code from the site
Classicunlocking.com for Blackberry Curve 8310 and unlock it easily using the unlocking instructions below...
Blackberry Curve 8310 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Blackberry Curve 8310 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
Oct 26, 2012 | RIM BlackBerry 8700c Cellular Phone
How do i save info to my new sd card
Under your blackberry system settings, storage/memory options you should be able to choose the SD card instead of the internal memory.
Mar 15, 2011 | CCM Cellular SanDisk 4GB Class 2 microSDHC...
Where to install memory card
Depending on your model of Blackberry the memory card will either fit in a slot on the side of your phone (under a cover) or if you remove the battery you will see a slot for the card. The full size adapter is so that you can read the card in a standard memory card reader plugged into your PC.
Jul 28, 2010 | SanDisk 2GB microSD Memory Card
The sandisk stop working on my blackberry 8310
simple this may occur due to a virus so what you need to do is to format the memory card
Jun 10, 2010 | SanDisk 2GB microSD Memory Card
My computer will not format my memory card for my blackberry
Put SD card into adapter format on PC Fat32,
put in blackberry should work fine.
Apr 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Format sd memory card 2g for blackberry usage
Dear,
Just format the card using PC. It is very simple. Right click on drive(card) and select format. It is ready to use.
Regards,
Rakesh Kumar
Apr 01, 2009 | SanDisk 2GB microSD Memory Card
Installing the 1gb card
Remove the sheel backside of your phone
remove the battery
now you see your sim-card
you place the sd-card just at the right side of the sim-card
lift the mediacard holder
insert the sd-card into the slot in the mediacard holder so that the metal connectors on the card will align with the metal connectors on your phone when the media card holder door is closed
close th media card holder door and slide the media card door away from its hinges to lock it
put back the battery and shell and you done!
If you still dont know, here is an demostrator how your phone works
Good luck
Dec 07, 2008 | SanDisk 2GB microSD Memory Card
Blackberry Curve 8310 Media Player display problem
it maybe reciving through a bluetooth connection shut of your bluetooth and check agian
Oct 16, 2008 | RIM BlackBerry Curve 8310 Smartphone
Unlock bb curve 8310, can you help?
It's a clear and fully detailed guide on how to unlock a BlackBerry 8310 ' Curve :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
Jun 14, 2008 | AT&T Blackberry Curve 8300 Smartphone
Cannot add music onto blackberry curve 8310 with sandisk 1 gb memory card
pls format the card from the blackberry device.
this should take care of the issue
Feb 27, 2008 | SanDisk Memory Media
SanDisk 2GB microSD Memory Card Logo
90 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
