Question about Sony Televison & Video
Mdl kp53v85 red is out of alignment and bowed
Please tell me which parts to replace
  • 505 Answers
Your convergence ICs are bad. They are about 20 pin chips located on the D board. They are on the largest heatsinks on the board. Check the resistors and fuses underneath or next to the heatsinks with an ohm meter to make sure all are good as they can fail with the ICs. This is a difficult repair but can be handled by a moderately skilled electronics tech. After all bad parts are replaced, run the magic focus to hopefully re-align the colors. If you have to go into service mode to re-align convergence data, the complexity of the repair just went up another notch. On a sony, service mode is tricky and a service manual would be highly recommended. Your tv uses two stk392-150 ICs (ic 1502 and ic 1505)
Posted on Dec 07, 2008
Sony KP53v85 T.V (52
the problemthat i am having with my sony projection tv kp53v85 is that the sound keeps cutten off and on
Dec 29, 2009 | Sony KP-53V85 53" Rear Projection...
Blue color is off and bowed at bottom
Needs the 2 convergence amplifiers replaced and then convergence alignment carried out(Could be pricy)
Dec 04, 2009 | Toshiba 50H81 50" Rear Projection...
Mithsubishi Projestion TV MDL VS-60609-Picture bow
Sounds like bad convergence chip. I think you can get a kit to repair it at www.tvrepairkits.com
You need to be good with a soldering iron if you plan on doing this yourself.
May 17, 2009 | Mitsubishi VS-60609 60" Rear Projection...
A-board for a sony big screen
yes its well worth a repair.
check or replace 1c205 on the a board.
5 blinks with this model number is :
replace q764 on blue Crt Pwb part number is 2sa1091. same transistor on the red and green just replace all 3 to make the job simple.
again the locations are q764/q706/q733
regards,
daniel.
Jan 15, 2009 | Televison & Video
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 24, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pioneer SD-533HD5 - Red bowing at the bottom of the screen
Convergence amp. IC's on power supply PCB need replacement.
Part # STK392-110 sub to upgrade STK394-160E. I use Hitachi ,
no re-calls! Not advisable to use generics......
Worth repairing unless you are ready for a change......T.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Convergence problem
Part # STK392-040 X 2 Do not use generic-they won't hold up.
I use Panasonic brand with no recalls------wholesale cost about
30.00 each. Always replace both at same time = more efficient.
After replacement, alignment may be needed = let me know.
Please rate this solution...................T.
Nov 12, 2007 | Akai PT5598HD 55" Rear Projection...
Blue horizontal bows/lines
Replace convergence IC's,then check alignment.
Use OEM quality ==I use Panasonic IC's with no call-backs.
T.
Oct 13, 2007 | Samsung PCN5425R 54" Rear Projection...
Red bow at top left and botton left of screen
Lost of high voltage on the vertical amp was caused the bowing. That was a simple tweak. I'm sorry to tell you that the high voltage adjustments are rather precise and have major interaction with each other. The HV circuit is also used to power low voltage circuits to gain efficiency. If one or more are not within spec, the process to recovery will require bench alignment of the various stages. Seek professional help or consider replacing. Good luck
May 21, 2007 | Philips 60PW9363 60" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
