Question about Panasonic TH-42PX75U 42 in. Plasma Television
Panasonic plasma internal speakers
No audio
3 Suggested Answers
SOURCE: i have a panasonic 50 inch tc-50px24 plasma tv. i
blinkin de red led tv panasonic plasma
Posted on Feb 13, 2011
  • 635 Answers
SOURCE: Panasonic TC-32LX60C LCD TV Internal Speakers have
Please check in the Menu under Audio section if you can disable the internal speakers. In the Sony and Samsung TV's you can. It will be in the bottom of the of the audio scroll Menu.
It will ask you TV sound Internal / External ?
Choose internal
Posted on Apr 01, 2011
Panasonic p42g10a how do I turn the tv speakers off to run home theatre system?
There is usually a location somewhere in you customer menu where you can turn the internal speakers off.
Page 34 of the owners manual.... shows "speakers" you should be able to turn them off & on there.
Jul 24, 2014 | Panasonic TC-P42G10 Plasma TV
Panasonic plasma t.v. Has a picture and no sound
Make sure the speakers did not get switched to off.
Or from internal to external if it has that feature.
Also see if sound when a DVD etc. is connected to rear av inputs.
If using a box, a receiver etc--unplug them all and wait a short while and plug back allowing all to try to reboot.
If none of this helps you may have a audio problem in the set--most of these sets the entire audio circuit is on the main board but a look inside at where the speakers connect to will answer that.
Jun 01, 2012 | Panasonic TH-50PX500 50 in. HDTV Plasma...
I have a new Samsung TV (LED 6000 series). I can not get my Sennheiser RS 120 to connect. I have plugged them into the audio out jacks at the back of the TV. They always worked perfectly with my old...
There is a possibility that internal speakers have to be turned off to direct audio output to the rear connector. You can confirm this by going to the initial set up procedure to disable internal speakers.
Jan 10, 2018 | Sennheiser RS 120 Consumer Headphones
I have a 42" plasma
The Logitech speakers z506 manual would explain what it needs for a source. RCA Audio outputs can be adapted to 3.5mm.
Jul 17, 2011 | Panasonic Audio Players & Recorders
Panasonic TC-32LX60C LCD TV Internal Speakers have never worked. Had audio hooked up through surround system. It's now a spare TV. How do I get audio through the speakers?
Choose internal
Apr 01, 2011 | Panasonic TC-32LX60 32 in. LCD Television
The sound does not come out of the speakers when I use my tv panasonic plasma, but when I use dvd,cd then sound comes out of the speakers, I have looked at the manual , help please, when it was set up this...
set tv in tv mode
go to audio setup then check the audio output settings. it should be in internal speaker setup,
then only u can hear the audio though ur tv. if it is in amplifier mode then the internal speaker will be off. check it first.
Jan 11, 2011 | Harman Kardon HS 200 Theater System
I have a panosonic plasma tv when i switch it on it tell me there is a speaker short and then switches it self of model number pdp507xda help
It's the internal circuitry problem. Try muting it and put audio connection to other speakers if it repeats, your TV audio system is internally dying.the audio connections has to be checked and faulty components should be replaced.
1. Speaker short.
Open it up and check the speaker connections. ONLY if you have basic skills working on electronics and don't have a warranty.
2. Sound Volume "Leveler"
Look in your sound option menu for a sound "balancer" option and turn it off.
If this doesn't work disable the sound and invest in that surround sound system (external speakers solution of your choice)
try this.for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the audio circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off. if the tv is connected to externalk speakers then check out without connecting the external speakers and see whether it works.if it works that means tv is perfect.but if tv is having inbuilt speakers that its confirm problem with inter audio circuit of try connecting external speakers at the back of tv and check out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | Panasonic PDP-428XDA 42 in. Plasma TV
Connect home theater to tv
Do you have the cables connected to line out on tv ? Do you have the correct source and audio type selected in the home theater (analog/digital/coaxial).
Jan 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
No screen saver
depending on your tv there is a function to turn screen off. most tvs come with this feature. on the remote there will be an power key with a red or black button. this is to turn the screen off. if it does not have this function and there is no screen saver setting on the dvd play there is not much you can do for this situation .
Jul 05, 2017 | Panasonic DVD-S97 DVD Player
Panasonic TH-42PX75U 42 in. Plasma Television Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
