Question about SanDisk Sansa m200 (2 GB) MP3 Player
Sansam200 skips three minutes of play time after it turns off
After my Sansa m200 gets turned off, it skips three minutes of play time. It just started doing this about a month ago, and I can't find any information on how to fix it.
5 Suggested Answers
SOURCE: San Disk Sansa m 230 512 MB
Your problem is probably beacause you accidently deleted "AudibleActivation.sys" from your "Audible"-folder. Format the sansa and then use "reset to factory settings" to make the file appear again. It might be a good idea to make a backup on your hard drive, just in case, and make the file hidden.
Posted on Mar 21, 2007
  • 155 Answers
SOURCE: Skipping songs
We could try formatting the player and after the format has been complete try updating the firmware of the player. Change the settings fo the player to MSC then connect to your computer, open my computer and right-click the player and choose format remove the tick mark on the quick format and after the format has been completed. Unplug the device and go to the sandisk website and download the firmware update and install it and when it ask you to connect the device hook the plyer and perform the update for the player. Note: It may be the songs on the player are not that properly transferred that why it is skipping and also the player might also have had bad sectors that is why we have formatted the player. Hope this helps.
Posted on Jul 22, 2007
  • 8596 Answers
SOURCE: Sansa Clip 2Gig skips... sometimes
download the Sansa Connect Recovery Tool from:
Posted on Feb 19, 2008
  • 10 Answers
SOURCE: Sansa m200 mp3 player problem...
check this out....
Posted on Sep 03, 2009
SOURCE: I accidentally dropped my Sansa Clip 4G on a wet
I dropped my Sandisk in the Ocean! I didn't even know it until it washed up on the beach. Of course, it would not start up and the small screen looked foggy (much like it does sometimes when I use it on a humid day...I juggle with it and it get's pretty steamy). I put it in a ziplock bag with 1/2 cup of salt (wrapped the sandisk in a paper napkin first) and left it there for two days. When I took it out, I tried to turn it on and got nothing. I set it down to do something else and out of the corner of my eye I could see it just powered up. It played just fine. For the next few days it powered up slowly. Now a month later, I can see that the connector where I charge it is getting corroded. Still, it works and charges just fine. Be aware that you need to have some patience and give it more than the normal boot-up time, based on my experience.
Posted on Mar 11, 2010
0 characters
1 Points
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
My mp3 player is frozen as soon as i turn it on it just come on and say V4.0.44A SANSA M240 1.0GB and thats it it won;t play or nothing. and its been like this for a long time.
All Answers page from Sandisk for the M240:
Looking for answer 34, when the player is not turning on:
Trying to reset performing the actions in solution 1. Next, when still not responding solution 2:
Looking for answer 14, when the player freezes. Telling to format the player. Follow up the instructions on next page:
Sometimes a firmware update or reinstall is needed to have the player function normally again. See next page how to install and use the Sansa firmware updater:
Manual for the M200 series in pdf format:
Need more help ? Just post a comment.
Nov 18, 2009 | SanDisk Sansa e250 MP3 Player
check this out....
Jun 21, 2009 | SanDisk Sansa m200 (2 GB) MP3 Player
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
Sandisk sansa m200
May be you can still send it back if under warranty. Never good idea to take things out like power buttons.
Oct 23, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa 240 will only play from the beginning of tracks
evey time i want to play a song,it will keep skipping songs,but its only showing me the artists
Oct 20, 2008 | SanDisk Sansa m240 MP3 Player
Cannot See Music Files on m200 Sansa
Swithc from msd to mtp to uncover hidden files - also make sure you do not have hidden folders option selected in Windows itself
Jun 24, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa won't play songs
my mp3 player skips songs while playing it does'nt play the whole song it keeps skipping
Dec 24, 2007 | MP3 & Digital Media Players
Reset button
1. There's no reset button. 2. Try removing the battery and keep pressing the power button for 1 minute. This is supposed to turn off the power. The other simple shut down is rather described to be a standby mode. Hope that helps. Amakorkos
Jun 10, 2007 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Have you tried removing the battery? Or maybe your battery is low. As well, if your mp3 player isn't turned on when you plug it in, that seems to affect if the computer recognizes it.
Nov 05, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m200 (2 GB) MP3 Player Logo
15 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
