Question about LG French Door Cabinet Depth Refrigerator 21 Cu. Ft. - LRFC21755
LG Fridge Freezer display has CF error code
LG dispenser display on a Fridge Freezer has ER CF displayed on it. Have tried a 5min power reset. Reverts back to CF code minutes after power up.
Fidge and Freezer seem to be working fine although water from the dispenser may be a little warmer than usual? The fan may be a little quieter than usual. (You don't really pay too much attention to those things until somethings wrong).
  • 5 more comments
  • david_wishar Dec 08, 2008
    Thanks for coming back to me so quickly.
    The model no. is GR-L207DTUA.
    It's a side by side type model rather than over/under.
    Thanks anyway. I'm actually in New Zealand.
  • Anonymous Jan 01, 2009
    lg refrigerator
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    I'm sorry, but the closest I could find was a model GR-L207 and that does not have numeric display. (only twin 5 bar vertical indicator lights) I'm taking a shot that this is a non- USA sold product (Canada maybe?) and I don't have access to all those, even though I'm only a couple hundred miles from the Canadian boarder.
    Perhaps you will have to check LG's web site for a service provider in your area.
    I did not find a ER CF code for a model LRFC21755. Could you check your model number again? Get it from the sticker inside the refrigerator section.
  • Anonymous Mar 17, 2014
    Moved fridge from old home to new home. Hooked it up and was fine for about 12 hours. Then er rs code came on digital display. How do I reset?
  • Anonymous Mar 22, 2014
    freezer stop working. dispensers not working either>there is a error msg
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Posted on Dec 09, 2008
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: http://www.searspartsdirect.com/lg-refrigerator-parts/model-LFX23961SW/3204/0161000/K0810254/00001.html . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
How do you fix icing sensor error (ER IS) on an LG lfx25974st Fridge?
My lg fridge keeps beeping saying the freezer temperature is fluctuating
Jan 20, 2015 | LG Refrigerators
LG GR-B206GTQA Fridge Freezer ER CF Error Code
The fan is almost certainly run by a sensor in the condenser. If it doesn't get hot enough, the fan doesn't run. Sounds like short of gas. Try wiring the fan to the compressor live and see if it runs all the time then.
Apr 18, 2014 | Refrigerators
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
We just had the regrigerator installed today. It was cooling and then we put the food back in and shut the doors and the readout now on the display where the temperature is says ER and CF. The water does...
If the unit was just installed you would call for service. Error Code Er CF -The unit will receive signals from the BLDC fan motor in the freezer compartment during normal operation. If more than 65 seconds pass without a signal from the fan motor, an "Er CF" error message will be displayed. The Cooling Motor Error is usually an indication of a faulty fan motor or loose leads. Customer service should be contacted immediately. IF you have any further questions message me back Thanks Rick
Sep 08, 2011 | LG LFX28978
I have an LG SXS side by side refrigerator that will not dispense water. The display shows FR & FF. If the supply is switched off and then back on again the display resets for a period of time. Over...
Er FF - Freezer Fan Error - This can be caused byfrost accumulationon or around the freezer fan. Unplug the unit for 3-4 hoursto allowthis to melt off. If error code persists, call Customer Service.
Jan 20, 2011 | LG LSC26905TT Side by Side Refrigerator
Westinghouse Model WSE6070WB*5 Error code: Cn Er
I recently had this message on my Westinghouse fridge. The CN and ER message stands for Connection Error. This is due to a power surge.
I suggest you disconnect the power cord from the powerpoint and switch off for 5 minutes.
When connecting, if you have a double power point use the other head as the initial one may be faulty and this may have caused the power surge.
Hopefully this will fix the CN ER message to disappear.
Jan 22, 2010 | Westinghouse Refrigerators
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Oct 12, 2008 | LG Refrigerators
LG LRFD25850ST gives ER CO code on door
There is a communications error between the control board and the display board.  Check the connector located on the top hinge cover.  Remove the hinge cover and check to make sure the connector is tightly secured.
Apr 12, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
LG French Door Cabinet Depth Refrigerator 21 Cu. Ft. - LRFC21755 Logo
2,619 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
