Question about Toshiba 50H81 50" Rear Projection Television
Picture is strobing
Imagine the flat screen is a sheet, and someone is flapping it forward and backward. That is what my picture is doing, it is strobing, for lack of a better word. It does it on different inputs, so it is the TV, and not the cable or cable box. It just started that today. I have unplugged it for a couple hours to see if it will reset or something. Any other suggestions? Is this something repairable or is it time to get a new TV? We have had it a couple months shy of 5 years.
  • 38 Answers
The problewm of your unit is in the chroma section. if you find a intermittent trouble my sulotion it could be a loose contact layout circuit. and if your not inclined with this job contact for a service technician.
Posted on Mar 06, 2007
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Flicking screen on Samsung UN60FH6003F, replaced main & power board and LSVD cable.
Check out the inverter board. It supplies the backlighting on screen so you see picture. If it is messed up it could be responsible for the flashing. Assuming you see a normal picture in between flashes!
Dec 08, 2015 | Samsung Televison & Video
What would make the screen strobe after turning on.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 30, 2015 | Televison & Video
Can't print pictures from my laptop. The printer always says paper jam but there isn't one
"Paper Jam" issues are common with printers. They most often occur right after there has been a paper jam. Most people (not necessarily YOU), don't take the time to read how to properly clear a paper jam in their printers and often yank the jammed sheets backward thru the paper tray. Most times you should remove the cover in the back and pull the jam FORWARD out the rear, or if the jam made it close to the output tray, then FORWARD thru to the output tray. Pull sheets backward can cause two issues. It makes tearing the paper easier. This can result in tiny pieces being caught in places where the printer detect them as a jam. The other issue is that pulling backward can damage the feed rollers that pull the paper into the machine, as well as the mechanical sensors that detect paper jams. If you cannot find ANY shards of paper in the machine, you may have printer damage that results in the jam indication.
Oct 10, 2015 | HP Computers & Internet
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
Flashing picture
I had the same problem with my 237V, I had to replace the power supply to fix the problem. I believe when it would work the output voltage of the power supply was around 19.2v. When the screen started to strobe the voltage had jumped up to 21.5V. A new power supply fixed it for me but now I think my main board is on the fritz.
Sep 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Calibration sheet for Visioneer Strobe XP100 Part Number 85-0110-200
I made my own with a blank piece of paper and a sharpie. Make a solid black strip about 1.5 inches wide about 1.5 inces down from the top (short edge). about 1.5 inches below that make another one about 3 inches wide. Mine were at an angle but it still worked. feed it striped side down small line first. so esentially the first strip hits the entire width of the scanner all at once then it will see all white again, then all black again but wider this time. then all white till the end of the page. I based my mesurments on a picture so i have no real measurments but mine did work. if anyone has an actual page please take some mesurments and post them on here plz. well hope it works for you.
Apr 05, 2009 | Visioneer Strobe XP 100 Path-Through...
Toshiba 50H81 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
