Question about RCA HD52W59 HDTV Projection Television
RCA ITC 222 Deflection board
I suppose I'm having the same problem as a lot of other people. The fl231 fuse is blown. The accompanying diode seems to be fine.
This may sound like a dumb question but I have to ask... I couldn't see where the wires on the flyback transformer were connected. So I figured I'll just cut the wires and then wire nut them and tape it up when I reinstall the board after replacing the fuse.
Is that going to be OK? I understand this transformer can really put out some high voltages.. and maybe that's why those wires are so well insulated.
  • cmarshall28 Dec 08, 2008
    Oh. That's not what I was hoping to hear. I already cut the wires. Maybe I should make up a story to tell my wife for why the TV isn't going to work now and just get another TV. It looks like this one is going to be trouble anyhow.
    Genius:
  • 1,030 Answers
DONT DO THIS. these wire carry several thosand volts. depending on the type of flybacks the wires can be removed at the other end of the wire. i tell you what i do at the shop very carefully remove unsolder the flyback.
Posted on Dec 07, 2008
  • Willie Howell Dec 08, 2008
    the other option you have is replace the flyback
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from www.tvrepairworld.com
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
RCA D52W14 Cable connector on the ITC 222 and ITC 222A signal
a good experienced tech might be able to do it for you .  other than that you will have to replace the SSB
Jul 28, 2010 | RCA D52W19 52" Rear Projection Television
The power is out
Replace the deflection board or power board. www.tvrepairworld.com has the parts for the RCA/ GE itc 222 series TVs. You ccan also call them and they will assist you in determining which one you require.
Jan 13, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 Coverage issue Responce
that definately sounds like the convergence ic's have failed, you can try to find a simular schematic here ( itc 222 ) http://www.eserviceinfo.com/equipment_mfg/THOMSON_2.html
also here is some other things to try
1 in the service manual that disconnecting BW001 & BW002 on the Converagence Amplifier board may remove the load on the Convergence Power Supply , so disconnect turn on power then turn off and unplug from wall , then plug those back in and then power up , ( if you already replaced fuse and resoldered flyback)
2 resolder the flyback pins
3 check fl231 again , replace if needed
let me know if that does it or if we need to check power at the fuse or another part of the cicuit , but definately resolder ( one of rca's biggest problems)
jason
Jan 31, 2009 | RCA HD52W59 HDTV Projection Television
Hey!!!!!
most likely cause is fuse FL231 on the deflection board is blown due to DL231 and CL230 needing replacement. You can get the parts at the following link with instructions on where they are located in the chassis. Heres the link look under the RCA Parts Category. http://servicemanuals.vstore.ca/
Jan 29, 2009 | RCA R52WH73 Projection Television
I HAVE AN RCA ITC 222 CHASSIS THAT THE CONVERENCE IS NOT WORKING , I KNOW THE PROBEM IS ON THE DEFLECTION PCB, BUT IF YOU REPLACE THE FUSE AND THE DIODE IT WILL NOT STAY FIXED , DO YOU KNOW THE FIX WSOLAR
the problem is not to do with the deflection! it is still working if you are seeing a picture, it is the power supply for the convergence. it isn't working at this time. it is usually a smaller separate pcb
if this supply isn't working the picture looks wacked. rca's seldom have an issue with convergence and are made better than most you will notice the heat sinks for the convergence output that are discreet and will outlast many other brands that use chips.put a dvm on the output of the supply to confirm. if power is there then the seldom problematic outputs is to blame.
Nov 11, 2008 | RCA R52WH73 Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Now power 1-9 blinks
You can get your deflection board completely rebuilt cheaper tha they want to look at it at the following link. The boards are completely remanufactured and have a full 6 month warranty. Heres the link, click on the ITC 222 deflection board under the RCA parts category.You can leave them a email if you want to ask any questions about the remanufacturing process.
Heres the link.
Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
oki this is an itc 222 or rca hd 52.... if your convergence option is not availvble in your menu and you have a bowed multicolored 3 d ish picture then this points to a special fuse fl231 if you can get this fuse and can solder then it should cost you about 5 bucks and 30 minutes to fix...ill give you more intstruction on how to do this repair. whats your model of your tv]
May 23, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
443 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
