Question about Olympus Camedia D-425 / C-170 Digital Camera
Auto Focus Problem
After my camera has got a knocked, some times, auto focus function is not working good, the target image see wrong, if you point the lens to another places and comeback to first position the auto focus work fine and image see good. Are there some way to adjust the auto focus?
  • Gustavo Duarte Feb 20, 2007
    Is it possible fix this problem by myself? Becouse the repair cost is to high.
  • 114 Answers
It´s pretty normal on that camera model, there was a problem on the focus system and they are fixing it when u send to a repair centre, they just don´t say it, but once u send it they will repair it, and will be fine.
Posted on Feb 20, 2007
SOURCE:
Hi there. i owned a Canon EOS 60D model camera. The problem is, its AF option is not working except Auto n 'C' modes. While i am trying to use it in M mode with AF, its not working but in auto mode an
Are you sure you did not put the AF/ MF switch in the wrong position? Although I don't think it would focus in Auto mode. In all other modes, are you sure you selected a (or more) focus point(s) in the centre of the frame?
When the selected focus point is on the side of the frame it won't focus on the parts you want it to focus. Then while pointing to the point you want the camera to focus, please press the shutter release button half and what till it focusses. Then press it the whole way down. Be aware the camera needs enough light to focus and certainly can't focus with a lens wit a min aperture of 6 or a larger number. On your 18-135 you can shoot at f16 because it will first focus on wide open and only close the aperture after you pressed the button.
Jan 27, 2015 | Canon EOS 60D Digital Camera
Won't focus properly on auto focus.
Depending on your lens, you may have an AF/MF switch. Make sure it's set to AF for Auto Focus. Try increasing your light levels. Does focus work in a good light setting?
You should have a button that looks like a matrix. Press this button to set your focus point. Use the joy-stick like wheel to select the focus point. Press it to select Auto Focus points.
Aug 27, 2013 | Canon EOS Rebel XSi Digital Camera
My photo's are not sharp and clear. What am I doing wrong?
you could be doing nothing wrong, These cameras have auto focus and when there pas there prime, you need to get them fixed basically.
If the output is out of focus more then likely the auto focus is your issue.
Hope this does help, would be considerate if you do leave a rating or feedback before you go, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 04, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
How and When to use AUTO FOCUS and MANUAL FOCUS of my contax t2 camera?
There are no rules or conventions for this. It is totally up to you to chose which method to use.
Sometimes when taking images in close up where a leaf or stalk may invoke autofocus to lock onto the wrong object to get a clear pic, then select manual so your subject is in focus
Depth Of Field is also associated with focusing, autofocus does not always deal well ith DOF situations. It might be better for you to get a simple book on digital photography to help you understand how to get the best results from your camera
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Contax T2 35mm Point and Shoot Camera
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Oct 11, 2009 | Nikon D300 Digital Camera
Hi there i have a auto focus problem. i used mt 50D for the first time on saturday, after about 100 shots Err99 appeared, i turned the camera off and took the battery out an the error message never occured...
The camera is having problems with your lens and this is why it goues into the error mode. Try first cleaning the interface contacts on the lens ( see enclosed pic ) . If this does not sort the problem out then the auto focus motor ( or related hardware ) inside the lens will need attention. Also try other lenses to see whether it is only the lens ( I very seldom see this sort of problem cause by the body ; it is always the lens that gives this sort of trouble )db49ae2.jpg
Nov 04, 2008 | Canon Cameras
DMC-FZ7 problems
Have you tried switching the mode dial to a flower icon?
The mode with the flower icon is the macro mode, you can shoot up to 5 cm from the subject.
Also, if you are very close to the subject, then the auto-focus may not function properly if the targeting area is not centered on the subject.
When I shoot macro with my FZ7K, I use manual focus, the auto-focus generally has trouble focusing up close.
I would suggest trying manual focus.
Jul 04, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-5060 Wide Zoom camera. It uses a contrast detecting system, to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-5060 Wide Zoom, the AF target zone automatically moves the to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Low light with auto-focus
All auto-focus systems need a fair amount of light or contrast to work efficiently. If possible, raise the ambient light if indoors. Search for an area within the desired focusing point with contrast to focus on.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Camedia D-425 / C-170 Digital Camera Logo
200 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
