Question about Dell E173FP 17" LCD Monitor
No power in dell e173fpf
Hello i have a problem with my dell e173fpf. no power , no led . i found that D854 (dual diode ) was shorted . replaced it with another kind of dual diode . it was ok and the monitors goes on . but i wanted to try again if without soldering the dual diode the led goes on or no . so i found that without it the monitor doesn't go on . so i resold it on the board but now it doesn't go on .i don't understand what happed . did the fact of powering it without diode had destroy another component ?
  • riadh tebib Feb 21, 2007
    helo tim!
    it was the first thing i did ! but the problem is the same ! i think powering it without diode have destroyed another component but i did't foun which
  • rlee2007 Nov 06, 2007
    I have the same Dell E173Fpf with the same problem. no power LED does not indicating. i checked the power supply board nothing looks buring. fuse ok .. where should I start checking
    Novelist:
    Champion:
  • 202 Answers
I would expect the same (new) part failed. Try another dual diode otherwise you may be chasing the problem around the board.. Good Luck, Tim
Posted on Feb 21, 2007
E173FPf.10-10,on the Dell monitor board a diode No. D854I have a schematic that shows at 10amps,but how do I find the voltage so as I can order a new diode,this doesnt show up on the diagram,thanks for...
I have one of those boards at my shop that I can look and get the information for you. What type of problem are you having with the unit? Diodes rarely go out. Email me at cclla1@gmail.com and I will get the information for you.
Sep 07, 2011 | Televison & Video
My Drink-O-Matic DR-3 power supply HYS68-12-50 crackles and led light flickers. The machine does not cool. It was a gift and worked about 6 to 9 months.
I have the same machine, my power supply was humming and the light completely went out. I took it apart and tested the dual package diode and found one the of the diodes went bad. I un soldered it and cross referenced it with a different part replaced it and now it works
Jan 11, 2011 | Sharper Image Drink-O-Matic
Service manual dell e173fpf
Try here:
http://elektrotanya.com/?q=showresult&megnev=dell&megnev2=e173&kategoria=&kat2=all
Most E152/153.172/173 have same problem, poor solder joints, blown fuse, shorted transistors.
http://s807.photobucket.com/home/budm/allalbums
Replacement bd: www.lcdrepair.us
Hope it helps. Please post back.
May 03, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell Monitor repairing trobleshoot
check the circuit of secondary line 1st check the all dioed must be shorted. then replace the horizontal transiistor out put.
Apr 18, 2008 | Gateway FPD2275W LCD Monitor
Dell E173FPf lcd- no picture,steady green light
E173FPf Mfg December 2004
This E173FPF has changed much inside from the November 2003 E172fpb which had the famous 4 identical transistors 5707 that would tend to fail in pairs. If your newer E173FPF displays a green power light and fails to display a picture try replacing the 220uf25v capacitors at C6 and C26. Test them with a volt ohm meter and they will test Ok, replace them anyway. Radio Shack did not have the 25v so I used the 35v, display works fine now. There is an E173FPF repair kit with directions available on Ebay if you don't have a parts store in your area and would prefer delivery.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 14, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Won't turn on
Could be a power supply issue. Maybe it's not getting enough voltage from the power supply unit. Could also be some bad solder points on the circuit board, or maybe a burnt capaciter.
Oct 04, 2007 | ViewSonic VX924 19" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
557 people viewed this question
Clive
Clive
Alun Cox
