Raymarine Ds500x Color Fishfinder: Ds500x Color Fishfinder With Bronze Thru Hull Transducer
Problem for Raymarine Ds500x Color Fishfinder: Ds500x Color Fishfinder...
The unit does not turn on.
By vfedele5 on Dec 07, 2008
The unit was purchased new and has only been used 15 or so times, It seemed to work perfectly. Then It started to not want to turn on once or twice and now its dead. Every now and then I hit the power button and the screen starts to come on for a few seconds and then dead again. I have checked the wiring , I'm getting steady voltage but nothing . Any ideas ??
Thanks Vinny
Same Problem
Mar 29, 2009
-   I have a similar problem with my Bottomline Touneyment 480 Max. The same issues....it just wont turn on.-   skocz
Solution #1
posted on Feb 15, 2009
Not Rated)
lifezcrappie
Rank: Apprentice
Rating: 0%, 0 votes
I read that if your battery is low that the X85 will not turn on. The lithium battery back up will save all your information when this happens.
Was this helpful?
Yes
No
Solution #2
posted on Dec 13, 2008
Not Rated)
themoneypitt
Rank: Guru
Rating: 86%, 73 votes
Hello vfedele5, The plug on the unit itself maybe the culprit. Check the voltage during power up, a resistance in the power line may be present. If the unit passes these test you have an internal connection error, bad internal connection, solder connection, ect. Merry Christmas.
Was this helpful?
Yes
No
Popular Solutions for Raymarine Ds500x Color
Questions and Unsolved Problems for Raymarine Ds500x Color
Do you recommend Raymarine Ds500x Color Fishfinder: Ds500x Color Fishfinder With Bronze Thru Hull Transducer?
Answer
Answer
what through hull transducer in airmar goes with a raymarine ds500x
Answer
I have a 50hp 4 stroke Honda engine, the unit powers back up on its own without a buttom press after... (More)
Answer
My unit comes on and after a short period " Internal High Temperature " appears and it...
Answer
Is there an update for Long Island Sound? I own a Triton with your model DS500X and it works... (More)
Answer
I constantly have vertical lines of snow on the screen (all screens) that interfere with the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Raymarine Ds500x Color...:
Top Marine Electronic Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Marine Electronic Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
