Having problems with HP DC5100SFF. The USB ports do not recognize devices all of a sudden. Using XP Pro SP3. One port works sometimes, but the others say can't find the driver.
    Genius:
  • 1,239 Answers
Hi
I think installing the proper drivers for your motherboard and operating system should work.
Find your drivers here (scroll down to see the available drivers and make sure you install the drivers for your operating system) or on the cd that belongs to your motherboard.
hi, see if you have installed any new devices/hardware to see if its conflicting, often grafics cards conflict usb devices, also just check that in the setup(when you boot up)that the usb ports have not been disabled or usb keyboard support hasn't been enabled/disabled. good luck!!
Posted on Dec 07, 2008
    Top Expert:
  • Computers & ... Master
  • 77,202 Answers
Have you gone into device manager to see it the USB ports are active? Try this go to device manager, remove the USB ports from the list of devices, then restart the PC, the system should recognize the USb ports and reload them and their drivers, you can also go to HP support on the net and email there support, it is free for life and they really know there stuff.
    Genius:
  • 1,550 Answers
Better uninstall the driver file completely and once again install the driver file from the Hp website with proper updates .
Also check whether that particular port is blocked (the port which says cant find driver ).
  • 13,433 Answers
Hey,
You may have to uninstall sp3 to get them to work again, then you could try installing sp3 again.
this thread maybe helpful
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=3311579&SiteID=17
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
Apr 04, 2017 | HP 250GB Pocket Media Drive 250 GB Hard...
My DameElec 2GB is not working on my XP Computer
try installing the flash drive once through add new hardware wizard from control panel. it might fix the problem for you. also plug the device directly into the usb slot present in the backside of the computer.
Jul 17, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
WONT BE RECOGNIZED BY MY COMPUTER SIEMENS FUJITSU (WINDOWS XP SP3)
Try the device in some other USB port on your computer.
Try the device in some other computer.
Mar 03, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
I have an HP Scanjet G3010 that I am using with both XP and Vista. The problem is that sometimes it works fine and other times I get an error message that states the following "One of the USB devices...
This is usually caused by a faulty USB handshake. The two most common causes are bad contact (i.e. bad USB port or cable) and interference inside USB hubs, especially the externally powered ones.
You can (usually) solve the problem by disconnecting the cable, waiting for the USB disconnect sound, and reconnecting the cable.
The real solution of course is to correct the hardware problem (which might be as easy as using another USB port, or as difficult as having the scanner replaced -- even if usually the problem is external to the device).
Dec 05, 2009 | HP Office Equipment & Supplies
Thumb drives not recognized by xp sp3 ...I haven't been able to find a solid answer why XP pro SP3 won't recognize a thumb drive inserted into a usb port in front or on back of the desk top as well as a...
wgnickless
Most likely there is another device that has the drive letter that the USB drive wants to use already assigned to it. The link below will show you how to change the drive letter in Computer Management.
How to change your drive letter in Windows XP
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
Let me know if you have any more problems or questions
Issken
Oct 15, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
Hi, I have an external disk connected to an usb port. Sometimes my computer stop to recognize the connection and my external disk doesn´t works anymore, until the next reboot. What can I do to resolve...
The only other solution other than rebooting is to remove the cable from the usb port and reinsert it. Sometimes the computer will recognize the drive and it will work properly.
Aug 13, 2009 | Microsoft Windows XP Professional SP3 Full...
I am unable to get my Windows XP Pro SP3 machine to detect either my external fireware drive or my Sony camcorder. It worked fine for years and suddenly w/o warning, it no longer works. I have applied...
was SP 3 installed at about the same time as these problems began? I have seen many problems"suddenly" appear after applying that SP..if you can uninstall it.
http://www.aa1consulting.com
Jul 26, 2009 | Microsoft Windows XP Professional SP3 Full...
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
