Question about Nikon Coolpix 5600 Digital Camera
Blueish pictures While taking the picture, it looks true to its color, but once it is taken it looks bluish. How do I fix this.
    Novelist:
  • 107 Answers
First thing to do is reset all your settings to default, consult your manual for instructions on how to do this. Your "white balance" may be set improperly for the conditions you are shooting under. If that does not work then comment here and I will advise further. David Millier Advance Camera Repair
Posted on Feb 24, 2007
Take a picture
your white balance is off ... go to your menu and change your white balance back to auto
Oct 14, 2012 | Panasonic Lumix Gh1 G10 G2
Pictures I have have recently shot all have a blueish hue to them. Is there a setting I can adjust? Thanks Ed
Artificial light is a different colour than daylight. Our eyes compensate, so we don't notice it much. Digital cameras can compensate too, but whether they do or not depends on the settings.
The setting you want to investigate is colour balance. If this is set to daylight, it will give an orange cast to pictures taken in tungsten lighting, and a greenish cast to pictures taken in fluorescent light. If it is set to artificial light, pictures taken in daylight will have a bluish cast. The best setting for most people is Auto. That will let your camera decide, and usually it will get it about right.
Jan 26, 2011 | Nikon D90 Digital Camera with 18-105mm...
All pictures show as blue
Artificial light is a different colour than daylight. Our eyes compensate, so we don't notice it much. Most digital cameras can compensate too, but whether they do or not depends on the settings. The setting you want to investigate is color balance. If this is set to daylight, it will give an orange cast to pictures taken in tungsten lighting, and a greenish cast to pictures taken in flourescent light. If it is set to artificial light, pictures taken in daylight will have a bluish cast. The best setting for most people is Auto, if your camera has it. That will let your camera decide, and usually it will get it about right.
Nov 11, 2010 | Olympus Stylus 720 SW Digital Camera
Daylight photos come with BLUE filter effect
Nov 10, 2010 | Konica Minolta DiMAGE Z10 Digital Camera
Photosmart A512v: colors are not true, more bluish....is it the ink cartridge that needs replacing or is it the paper????
In the setup menus, try changing the ambient lighting from flourescent to incandescent or daylight. This is the most comon culprit when pictures have a definite bluish hue to them.
Aug 18, 2010 | HP Cameras
Picture turns on and off and the color is a blueish red
yes. you are not getting green. sony has a circuit that if the picture is not perfect, it will shut off. two solutions....one, take off back and with the tv on, tap pretty hard but not hard enough to break it, on the neck of the picture tube with the plastic end of a phillips screwdriver. this will shake the old sediments in the crt. the tv will probably shut off if you do it right. tap harder and harder many times. fixed. two, rejuvinate the picture tube. fixed. easy
Nov 13, 2009 | Sony KV-27S66 27" TV
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
Orange projection lamp on. Picture is a bluish green, no true white.
If you are in warranty contact Lg electronics since they own Zenith. I was having similar difficulties and they are sending me a replacement tv even though I am out of warranty by 3 years.
Jun 09, 2008 | Zenith D52WLCD 52" Rear Projection...
Bad Picture Blueish picture
If the red gun stops working it could make the picture very blue-greenish. This could be caused by a number of problems, including a coolant leak, but it's most likely a bad electrical connection somewhere in the set.
Best left to a professional repair guy, frankly.
Mar 19, 2008 | Samsung HCM5525W 55" Rear Projection...
Nikon Coolpix 5600 Digital Camera Logo
35 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
