Question about Philips 42PF9830A 42 in. LCD Television
Pencil thin red line going down lefft hand side of screen
When you touch it with your finger lightly the line disapears can it be fixed and would it be expensive
  • 505 Answers
Unfortunately, pixel thin lines are usually failures of the actual panel. If you can touch it and effect the problem, it depends on where. If it is in the middle of screen or away from the edge, you have broken connections on the TFT layer of the lcd panel.. meaning you need a new lcd panel. If you touch near the edge to effect, it is possible that the ribbon cable inside the lcd panel could be reseated to resolve. Opening the tv is one thing, but opening the lcd panel is another, its quite tricky and dust can get in between the layers. Only attempt if you have good disassembly skills and some compressed air to keep the dust out of there. The ribbon cables are very fragile and repairing by reseating is a hopeful but unlikely solution. A new lcd panel costs about as much as a new tv. Might just live with the issue or use as a tv for the kids.
Posted on Dec 07, 2008
Touchscreen calibration
does lightly swiping your finger across the screen from the bottom left corner across to the upper right corner? there are different swiping motions that perform commands.
Dec 04, 2013 | Elo Computers & Internet
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
info@back2lifeelectronics.com
Nov 25, 2012 | Televison & Video
Samsung LE32C450E1W there's a red thin line going
try tapping your finger on edge of the screen where the line starts/ends... it works for me... its a lose connection normally with the rubber seals that have connections in them that lead to the circuit boards inside.... try it and let me know...
Feb 10, 2012 | Samsung Televison & Video
I have a veiwsonic n3752w LCD TV which is 3 yrs old,the screen on the left hand side as you look at it has a coloured line, pencil thin, and with the colour of green. This green pencil line is about 6...
A LOT OF THE LCD,s have cold solder joints, Inspect it with a magnafiying glass or somethingfor bad solder joints,bad,or burnt caps,or resistors, call ENCOMPASS PARTS DISTURBUTION for parts or service manuals.1-800-638-3328
Feb 15, 2010 | Televison & Video
I have an LG Plasma Model#DT42PY10X. IT HAS A RED LINE RUNNING DOWN THE RIGHT HAND SIDE AND i WOULD LIKE TO KNOW HOW TO FIX THIS PROBLEM. THANKYOU
Hi:
If the line is less then 2 inches wide this us a good indication of a bad PDP panel (Screen) usually very thin lines indicates a failure in the screen itselg, altho you might try replacing the upper and lower buffer boards to ensure its not the screen. You might want to take off the back and try reseating all connectors leading to the buffers and the Digital board. But in my experience thin lines less then 2 inches usually results in a bad PDP.
Jan 30, 2010 | Televison & Video
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
Blue line down left hand side of screen
If this is a very thin (pencil line) line, The problem is the panel. I hope that this is in warranty. The panel cost more than the TV. If it is larger than that. The problem can be the main control board ( if it is a LCD TV). If it is a Plasma TV the driver board is bad.
Jun 11, 2008 | Samsung Televison & Video
Thin Red Line on LCD TV
I had a similar problem with my LCD screen TV, and to my dismay, my warranty just ran out. A thin red line began to appear on the right side of the screen, and since many online and expert sources pretty much say replace the expensive LCD screen or get a professional to fix it (in which I suspect to be a business plot to get people to go to pricey experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10 minutes. Turn it back on and see if it disappears or improve. (This is the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV (cables, power chords, etc.); you could even try unplugging and replugging the chords/cables. Turn the TV back on and see if the red line disappeared or improve. (This is the one I heard worked for others.)
If the above doesn't work then I'm afraid you do have a bad panel on your screen and will need to call in the experts or get a new TV. I hope this will help. Best Wishes.
Apr 01, 2008 | Televison & Video
Philips 42PF9830A 42 in. LCD Television Logo
416 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
