Question about Garmin eTrex GPS Receiver
Using French grid reference system
How can I use the French grid reference system with my Garmin Etex I bought in the UK? when I scroll through the possible country grid systems, I seem to have many European options but not France. Is it possible or do I need to download something? Thanks John
UTM GPS position format, WGS 84 datum point if my memory serve correctly
Posted on Aug 29, 2007
Does aby know if my Garmin 1310 can use OS grd references instead of longditute and latitude? If so how is it set up?
Unfortunately Garmin satnavs do not allow OS Grid References instead of Longitude and Latitude. However if you need to find the Longitude and Latitude of a point it can be done by going to http://www.gorissen.info/Pierre/maps/googleMapLocationv3.php Zoom in on the location you want and left click on it. The longitude and latitude will appear in a box to the right of the map. You need to set the co-ordinate system of the satnav to match the longitude and latitude format of the satnav. To do this touch Where to, Co-Ordinates, Format. Enter the co-ordinates and touch next. It's not an ideal solution but it might help you out if you're stuck.
Aug 09, 2010 | Garmin GPS
Grid reference
If you mean the WGS or MGRS grid reference, you have to change it in the 'navigation' options.
Dec 25, 2009 | Garmin eTrex Legend GPS Receiver
I'm attempting to re-install maps on to my 7 year old Legend using the 'save to device' button. I get the following notice-'Your GPS does not support map transfer'. Why does my GPS no longer acccept maps...
Garmin Express cannot be used to transfer firmware to the etrex Legend. Use:
http://www8.garmin.com/support/download_details.jsp?id=25
Legend/Vista/Etex (H)Cx, any unit released prior to the Colorado) have map limits. They will only read 2gb of maps on a card (even if the card is larger) and will only read 2024 segments.
You would have to ask Garmin support as to why you cannot use the old disks. It may be irrelevant, but all methods of updating a Garmin do NOT work on all Garmins regardless of age. Even a utility that does work may work only if it is the version applicable to that generation of Garmin GPS units.
FYI, even if you have lifetime maps (free), you will only get free replacements for the maps that came upon the Garmin. An Australian Garmin with free maps will not allow you to get free maps while in the USA. You would have to pay for such.
Sep 06, 2017 | Garmin eTrex Legend GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
User manual in french
Contact Garmin using the information on the web page:
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Peter
Feb 02, 2009 | Garmin Nuvi 680 GPS Receiver
Garmin Etrex - ORdnance Survey Grid reference nos
You shouldn't have to connect to a computer. I don't have an OS map in front of me but I'm guessing they use UTM with a WGS 84 datum (if the map was produced after 1984 that is). Got to the Setup page then select Units. Change Position Frmt to UTM/UPS and Map Datum to WGS 84.
Jul 29, 2008 | Garmin eTrex GPS Receiver
Flex Grid
The most common multidimensional array, the two dimensional array table, is best presented to your users in row and column format. The grid control offers a convenient way for you to display table data to your users. The users can navigate the table's values using scrollbars. Therefore, the grid control does not have to be as large as the table, because the grid control automatically displays scrollbars.
To add the flex grid control to your toolbox, select project and components. Add the flex grid control:
lesson97-1.jpg Once it is added, you will see the yellow flex grid control in your toolbox:
lesson97-2.jpg When you place the grid control on your form, you will have to resize it before the control takes on a tabular appearance. As you expand the size of the control, it does not look to much like a table. The problem is that the table's default number of rows and columns are two. To fix this problem, you must configure the rows and columns in the properties window:
lesson97-3.jpg lesson97-4.jpg lesson97-5.jpg The grid control supports fixed rows and columns. These refer to rows and columns in a grid control that do not scroll when the user clicks the scrollbars. The fixed rows and columns provides labels that describe the data. The fixed rows and columns are often called row and column headers.
lesson97-6.jpg When working with the grid control, much code is needed to provide the grid with functionality. Call statements are used to break the code required by the grid control into smaller, more manageable procedures. This is referred to as modular programming (which refers to the practice of placing code with a single purpose in a general subroutine procedure and then calling the code from a second procedure.)
Here is the code for the form load procedure (this example is based on the computer disk example used in the last lesson)
Private Sub Form_Load()
Call SizeCells
Call CenterCells
grdGrid.Row = 0
grdGrid.Col = 1
grdGrid.Text = "Single Sided; Low Density "
grdGrid.Col = 2
grdGrid.Text = "Double Sided; Low Density"
grdGrid.Col = 3
grdGrid.Text = "Singled Sided; High Density"
grdGrid.Col = 4
grdGrid.Text = "Double Sided; High Density"
grdGrid.Row = 1
grdGrid.Col = 0
grdGrid.Text = "3 1/2 inch"
grdGrid.Col = 1
grdGrid.Text = "$2.30"
grdGrid.Col = 2
grdGrid.Text = "$2.75"
grdGrid.Col = 3
grdGrid.Text = "$3.20"
grdGrid.Col = 4
grdGrid.Text = "$3.50"
grdGrid.Row = 2
grdGrid.Col = 0
grdGrid.Text = "5 1/4 inch"
grdGrid.Col = 1
grdGrid.Text = "$1.75"
grdGrid.Col = 2
grdGrid.Text = "$2.10"
grdGrid.Col = 3
grdGrid.Text = "$2.60"
grdGrid.Col = 4
grdGrid.Text = "$2.95"
End Sub
Notice how the form load procedure is used to populate the cells in the grid control. To control cell size and cell alignment, two smaller procedures are created and each procedure is called by the form load procedure.
Private Sub SizeCells()
Dim intColumn As Integer
grdGrid.ColWidth(0) = 1100
For intColumn = 1 To 4
grdGrid.ColWidth(intColumn) = 2200
Next intColumn
End Sub
Private Sub CenterCells()
grdGrid.ColAlignment(intColumn) = flexAlignCenterCenter
Next intColumn
End Sub
Notice that the size and alignment procedures are only applied to columns 1 through 4. Column 0, which is a fixed column reserved for labels, is not formatted using either of the above two procedures.
Here is the final result:
Mar 26, 2008 | Computers & Internet
LG LRFD22850 Replacing support grid for bottom crispers in refrig. Need help.
It is a challenge to replace those grids.  Instead of trying to fit the support grids into the frame, bend the frame slightly to fit the grids.  You will need to remove the steel support from the frame before bending the frame.  That is what I have been able to do when I have those problems.
Oct 11, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
British grid
You should be able to get it from the set-up menu - units - british grid.
Oct 02, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex GPS Receiver Logo
1,046 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
