I installed an old Lexmark Z 705 and I think it has plenty of ink but it is barely printing. Is there anyway to rejuvenate the cartridge of clean the contacts if it is just "dried out?
  • 20 Answers
GO TO LEXMARK.COM/SUPPORT PAGE, MAKE SURE TO WRITE DOWN THE SERIAL NUMBER OF YOUR UNIT TO FIND ITS USER GUIDE, THE SITE SHOULD HAVE A PDF. VERSION OF THE USERS-GUIDE FOR THAT PRINTER, CLEANING INSTRUCTIONS FOR THE HEAD SHOULD BE THERE...JON T
Posted on Dec 07, 2008
Is it true that both my new Lexmark Prevail Pro 705 print heads quit printing in color is because I didn't use Lexmark OEM ink cartridges?
Some Lexmark cartridges have an RF chip mounted underneath the label on top. Most of these are set to self destruct on first use to prevent refilling. You probably need to risk the cost of a new cartridge to find out if it is a cartridge problem or a printer problem. Unfortunately you should not take out a cartridge or replace one while the machine is powered. The system also frequently registers an serial number on the cartridge and stores it to prevent "hot swapping" cartridges
Dec 11, 2017 | Lexmark Prevail Pro705 Wireless AIO...
Lexmark 730 not printing
Regarding the Lex1 cartridge's no printing/severe fade (or similar) during printing, my answers are provided below:
For the poor print quality problem (degraded image quality) you are observing, we suggest you first visit the "Print Quality" page of the "General Information" section of the Inkjet 411 website and follow the suggestions provided: http://inkjet411.com/?page_id=1432
A. 1. Cartridge & Printer maintenance should also be evaluated - ensure both ink cartridges and flexible driver contact cables (where the cartridge interfaces to the carriage inside the printer) are thoroughly clean: http://inkjet411.com/?page_id=1519
A.2. Perform a hot-water flush on the suspect ink cartridge, refer to video procedure here: http://inkjet411.com/?page_id=1519
A.3. Run a quick test print to evaluate cartridge performance (i.e. 4-color test print):
http://inkjet411.com/?page_id=146
For information on North American ink refill services (for Lexmark 1, 2 and 3 ink cartridges) at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced Lexmark printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jul 16, 2013 | Lexmark Office Equipment & Supplies
I have gone through $100 in ink this month alone for my Lexmark 705 Pro Prevail. It prints like 20 word doc pages (not photos) and then it says it is empty again, and the cartridges need constant...
Check the settings of your printer, either in the software that came with it or the printing preferences in the Control Panel. If your ink tone is set too dark, it could be using a lot of ink. If this is not the case, then:
1) Clean the ink cartridges
2) Replace the ink cartridges as they may have expired. 3) Replace the printer and find one which uses cartridges that can perform more copies in a single fill.
Jan 24, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
My Lexmark prevail pro 705 has stopped printing anything colour even after i have replaced all the cartridges??
This article on How to Troubleshoot the Vizix Ink Technology will help fix print quality problems on your printer. To run the Deep Clean Printhead function on your printer -> on the printer operator panel, press Setup -> Maintenance -> select Deep Clean Printhead. Your printer will then print the test page. Hope this helps. Thanks.
Jan 11, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
I put a new ink cartrige and printer prints low coulour tone.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
My printer, a Lexmark 1300 series USB printer, will not print in black ink. It has plenty. The ink is proper lexmark ink. It just appears to not be looking at it's black ink cartridge at all as when I put...
Check your printer preferences and be sure that you're printing in the right way. Select grayscale and see what's happen.
Delete all printer pending jobs.
Take out the cartridge, turn off the printer and wait 5 min.
Turn on the printer, insert the cartridge and try again.
If nothing happens, replace the cartridge
You will find more info here:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
Oct 09, 2008 | Lexmark Office Equipment & Supplies
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
Incorrect ink level reading
kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
41 people viewed this question
jasbo
jasbo
