Question about Dell E173FP 17" LCD Monitor
Problem in LCD dell Monitor 17"
Dear Sir/Madam When i plug in the monitor to my CPU i can get a messege the "Power save mode press any key to continue" but after pressing the key nothing happened, the monitor power button light become green when u press key and again gets yellow please solve this problem. Inayat
  • inayat ullah Feb 19, 2007
    Dear Sir
    I have done all these thing, when i start the windows i just get this messege in the white font and black screen "power save mode press any key to continue."
    inayat
  • Badandy55 Jan 20, 2009
    I have hooked monitor to another computer same thing
    President:
  • 2,961 Answers
Check the pins in the monitor cable and the connector in the back of the pc aren't bent. Have you any way of checking the monitor on another pc or laptop to check that it's not faulty. If you have a seperate graphics card (this will be in a seperate slot away from other connections) check that it has not become unseated or push down on it gently, incase you diturbed it on connection. Do you get any beeps on start up?
Posted on Feb 19, 2007
  • andrew pester
    andrew pester Feb 20, 2007
    This will tell if it's a memory fault or graphics.
When I turn the monitor on I get a message "In
Most Dell LCDs have multiple inputs and they will go into "standby" while waiting for a signal from your PC. This happens when your PC goes into "sleep" mode or if you are sure your PC is not in "sleep" mode then usually the LCD is not in the correct input selection. Check the input selection for the appropriate input. As always, make sure the cables are securely connected. Hope this helps.
Jun 15, 2011 | Dell E173FP 17" LCD Monitor
Dell 19' flat screen monitor
Check that the graphics card has not become loose in the computer.
Oct 22, 2007 | Dell E173FP 17" LCD Monitor
How to deal with "entering power save mode
-that message usually appears if there's no signal coming from the CPU. If you have another CPU, try plugging this monitor to it.
Dec 22, 2010 | Dell E207WFP LCD Monitor
Monitor does not activate when computer is turned on - it goes blank - when you press a button on the front of the monitor it states that the computer is in in sleep mode press any key to activate - the...
May be the problem comes from the Cpu.
Try to see if the cable from the monitor is firmly connected to the cpu.
One thing more may be the vga card is having problem.
Try to test the screen with another Cpu. Or the cpu with another monitor.
The amber mode is normal as the screen is not receiving signal from the cpu.
At times the memory chip also report this problem (no display or sleep mode)
Do hear any beep sound or any other Errors??
OK try this
Cheers Uttam
Jun 12, 2010 | Dell E176FP 17" LCD Monitor
L1718S won't come on
hi
my dear LCD monitor dosn't have power saving mode it's from your CPU
may be you have problem with your Display setup from your CPU
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
My monitor states its in power save mode.when i press any key,nothing seems to happen.
To bring the computer out of the power save mode press the "Windows" key once and release, wait one second, then press enter. The system should come out of power save mode. The Windows key is the key with the Microsoft Windows Symbol on it. Another solution would be to disable power management.
To disable power management, right click on the desktop, click on properties, screen saver, then Energy Savings Settings button.
Change all the settings to "Never", then click on "apply" and "ok". Power management has been disabled.
Apr 29, 2010 | Dell E173FP 17" LCD Monitor
When I turned on my computer, it said it was in power saving mode and to press any key or move the mouse. Did that. Now I have a black rectangle in the middle of my screen that says, "Positioning,...
Your Problem Is not in your Monitor Its in your CPU. Your CPU is not giving Display Signal to Monitor that's why Monitor goes to power saving mode. try to open Your CPU and remove RAM Clean RAM Slots and Fix it Again. Try to Boot now.
Mar 11, 2010 | Dell E172FPt 17" TFT LCD Flat Panel...
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Monitor not receiving data from computer?
If you did not hear any beep from your CPU, then the problem is in the system not the screen.
Try connecting the screen to another computer and try also a working screen of a friend to your computer...
You'll find out that either the screen or the computer...
Good luck... post me back for your result.
Don't forget to rate too.
Thanks...
Jan 29, 2008 | Dell E176FP 17" LCD Monitor
In power save mode
Try hitting the space bar on the keyboard. Does the mouse work normally?
Nov 30, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
171 people viewed this question
Clive
Clive
Alun Cox
