Step 1 : Push Power switch by continue (Tekan Power On/Off) Step 2 : inserrt plug(Masukan Power, Power Tetap di Tekan) step 3 : Tekan Tombol Reset 1x, lepaskan Tombol Pwr, Tekan Reset dua kali lagi Sampai Menjadi 0 (tekan tombol tanpa jeda) Step 4 : Push + display change from 0 to 1 (tekan tombol + untuk merubah 0 ke 1) Step 5 : Push Power switch again , Printer will be print 1 page(tekan tombol power –> tombol start sampai ngeprint 1 hal.) step 6 : Open cover (buka tutup printer) Step 7 : Unplug (cabut kabel power) Step 8 : Take out ink 40 and 41(lepaskan catridge 40 dan 41) Step 9 : Insert plug again (pasang kabel power) Step 10 : Push power switch (tekan tombol power) Step 11 : Open cover (scan cover) (buka tutup scaner) Step 12 : Inksert ink 40 , 41 again (masukan catridge 40 dan 41)
E5 - The ink cartridges are not installed or a non-supported ink
cartridge is installed , or the ink cartridges are not installed
properly..
In certain models of Canon Pixma printers such as the Canon MP160 and
Canon MP150, you may receive an E5 error when trying to print. In this
state, you will not be able to use any of the functions of your
printer. The error itself is an ink cartridge error. It may be that you
are using generic or off-brand ink cartridges in your Canon Pixma
printer. Canon Pixma printers do not work with other brands of print
cartridges; invest in Canon brand ink cartridges and this should take
care of your problem.
Hello, make sure you removed the orange tape from the cartridge. usualy E5 is when the color cartridge is faulty but if the orange tape is on the cartridge it will show E5. if you removed the orange tape an it still shows E5 go with the cartridge to the store where you purcess it for excange.
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed. Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur."
E5 error code occurs in certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
hi, CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
E5 - The ink cartridges are not installed,
or a non-supported ink cartridge is installed, or the ink cartridges are not
installed properly. E28 - Ink cartridge temperature rise error.
Replace the cartridges. Call to authorized service center.
hi
try to install a new driver from here
http://support-my.canon-asia.com/EN/search?canonsearch=1&lang=EN&category=Multifunctional+Printers&series=PIXMA&model=PIXMA+MP160&menu=Download
otherwise ur error code means
The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly. Install cartridges properly.
so try to clean the cartridge pinout well by using Acetone or something like that also try to clean the pinout of the cartidge mount inside the printer when it's power is off.
Empty cartridges may cause this error. Here is the error code list for your printer
E2-2 = No paper (ASF) E3-3 = Paper jam E4 = No ink E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly E8 = Waste ink absorber full, or platen waste ink absorber full E9 = The connected digital camera / video camera does not support Camera Direct Printing E14 = The Ink cartridges whose destination are wrong E15 = Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 = Failed to scan head alignment sheet E22 = Carriage error E23 = Paper feed error E24 = Purge unit error E25 = ASF(cam) sensor error E26 = Internal temperature rise error E27 = Waste ink absorber full or platen waste ink absorber full E28 = Ink cartridge temperature rise error - E29 = EEPROM error E33 = Paper feed position error E35 15 = USB Host VBUD overcurrent error - USB E37 17 = Abnormal motor driver error E40 20 = Other hardware error E42 22 = Scanner error If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
First take a smooth cloth or cotton
take a cleaning liquid like spirit, thinner etc., (note - not cleaners)
clean the golden chip with out giving much presser
in the same way clean the other side of the printer also
now test it
