Hi i have a Dell Dimension E521 desktop and connect to the internet through an ethernet cable to a BT Hub. This has work up to yesterday when we could not connect.The pc advises it cannot find a network. My laptop can still pickup the hub through wireless. unfortuately i do not have wireless on my PC. I have been on the phone to BT and they state that it seems the PC is not picking up the Internet ip address which i beleive should be 192 or 172. when i do ipconfig it is picking up a ip address of 269.. they advised that i should contact dell and find out how to delete and then reinstall my network adapter. Dell want 39 quid to answer any of my questions. Could you talk me through what i need to do thanks
    Scholar:
  • 174 Answers
Its sure an IP conflict is there and i hope you don't have a router - a modem is there so that when you connect to the internet, computers will get ip address from your service provider and not from your device which is not having that function because of no router. Kindly check in your network properties that you have specified any manual IP address delete it and keep the option obtain Ip address automatically. Before all this you have to go to the my computer right click and select properties then hardware ->devicemanager ->networkadapters - under that you uninstall all the adapters and restart your pc
Thanks
Hothawk
Posted on Dec 07, 2008
I cannot get ethernet connection from BT hub 3.0 on my dell inspiron 5160
try connecting through an ethernet cable. see what happens. Install the appropriate modem driver and network driver from support site.
post your comments if solved/not solved
Hope this helps
Dec 22, 2012 | Dell Inspiron 5160 Notebook
Can't connect to internet
for windows xp please try this link; http://www.dell.com/support/drivers/us/en/04/DriverDetails/DriverFileFormats?DriverId=6DYM2&FileId=2731095998&productCode=dimension-e521&urlProductCode=False
for vista try: http://www.dell.com/support/drivers/us/en/04/DriverDetails/DriverFileFormats?DriverId=6DYM2&FileId=2731095998&productCode=dimension-e521&urlProductCode=False
Jun 12, 2012 | Dell Dimension E521 PC Desktop
Monitor stays black what can we do to fix this. It was working yesterday....
Well all things in life stop sometimes. You can check the connections of all cables. You can connect the monitor to another pc to check if its the monitor our the videocard of motherbord of your computer.
Jan 12, 2011 | Dell Dimension E521 PC Desktop
Hi, I have a dell dimension e521 I hook up a old monitor to it and, it work but whei i hook up a new flat screen monitor it said (can not display video
Are you using the same VGA cable. Try to use the same VGA cable which is there is in Old Monitor
Though it can be issue with the resolution setting also of the Video
For that when you plug in your desktop to old monitor bring the Resolution to the minimum and then Connect it to your New Monitor
Jan 06, 2011 | Dell Dimension E521 PC Desktop
Cant get on the internet
The longer the cable, the slower the connection.
It should work with the cable as it is not "too" long.
I would try turning the modem and router off for one minute and then turning back on.
Jennifer
Dec 29, 2009 | Dell Dimension 2400 PC Desktop
Last week I put a 4-hub on my desktop and laptop. one wire from wall to main hub, one ethernet cable from hub to laptop, one ethernet cable from hub to rear ethernet port on desktop. The internet on the...
check if we are getting good ip address 192.xxxxxxxxxxxxxxxxxx
not the 169.xxxxxxxxxxxxxx
relese renew if 169.xxxxxxxx is the case
if no reply.. try using another cable and check the connections
Sep 20, 2009 | Dell Latitude D600 Notebook
Cannot connect to internet thru ethernet jack on computer
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
Jan 05, 2009 | Dell Dimension E521 (D10E16) PC Desktop
How to add Wirless & Ethernet connections?
The only difference in using a wireless hub is that it will go between your router and your computer. The advantage is you can take your computer anywhere within range and connect using your computers wireless card (if you have one).
You won't need any more equipment or memory and most wireless hubs come with instructions. If they didn't give them to you, just Google the manufacturer and model of the hub and you should be able to find them easily.
After you've set up the wireless hub (which you can still connect to via your ethernet cable). your computer should notify you of wireless networks available. You have a utility to set this up within the control panel.
Let me know if this helps
Dec 21, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
