Question about Sewing Machines
Stepping motor error on embroidery machine
Hi Benimur,
You helped me pout with this same problem a week or so ago. The machine did work fine for a few days, but now the same message comes up again. "Stepping motor error"
I followed the same advise you gave last time in checking the bobbin area, made sure everything was clean-all seems well there.
Could the problem be more serious than first thought?
Would appreciate your assistance.
Sue Bazant
    Brigadier General:
  • 6,966 Answers
Hi again and welcome back to FixYa.
It is nice of you to remember. To your concern, possibilities are:
  • if the grinding noise is coming from the bobbin case area, then pls ensure that nothing is stuck/caught there, it would only take a small foreign object to trigger the problem; or
  • verify that the embroidery carriage in its parked/original position;
  • there would be a sensor/switch that tells the computer that the embroidery carriage is back. Pls check that if the carriage is back and see if you can check the sensor/switch;
  • worst case scenario is that the controller's circuit board is faulty. In some case, it could just be the wires or connection leading to the controller board.
Good luck and Thank you for using FixYa again. Happy Holidays.
Posted on Dec 07, 2008
Need help, I keep getting error c 12 hoop size is smaller than embroidery data, I have the right size hoop on for the embroidery design I' using.
Perhaps the machine is not recognizing the hoop you have installed. Could be a computer component or software glitch or something wrong with the hoop itself.
You might try contacting a local machine dealer for support or contact the online manufacturer support.
Dec 19, 2015 | Sewing Machines
On an Elna 9006 sewing machine I have an error that reads ( stepping motor error) what does that mean.
Time to get this machine a repair shop. Motors in embroidery unit may be bad or headed that way...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 11, 2014 | Sewing Machines
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
My Singer Futura CE-250 Continues to give me an "Internal Error" message
You need a technician for this type of problem.
Electronic machines have built-in 'traps' that not only indicate when an untrained person has opened up a machine (thus voiding any warranty) but that may also interrupt circuitry that may keep the machine from working once the electronic part is reconnected.
Apr 24, 2017 | Singer Sewing Machines
Step motor error Janome My Craft step motor error shows up on screen and then stops. Turn machine off, sometimes comes back straight away then another time it may be a day or so later. Is this a motor...
If it really is your motor overheating, you either need it serviced, or replaced, possibly with another machine which is more suited to the type of sewing you do.
Feb 19, 2009 | Janome Memory Craft 9000 Computerized...
Top thread wrapping around hook under needle plate then jamming
Could be the needle is the incorrect size or the thread is not compatible with the embroidery or both. :)
Oct 31, 2017 | Singer CE-100 Futura Computerized Sewing...
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
JANOME MEMORYCRAFT 8000 STEPPING MOTOR ERROR
if you ever have this problem, it is because you have had something in the way of the embroidery arm at the back of the machine, so it has not been able to move freely; you'll get a terrible noise as the machine is unable to do what it wants, slips gears or something and then can't bring the arm to its home position. But fear not, i have found if you turn the machine off and gently push the arm back home to touch the machine as it is the start position, when you turn it on, it will work fine and no harm done. just make sure the arm can move freely before you start embroidery!
Jul 11, 2008 | Janome Memory Craft 9000 Computerized...
Turn off the machine, pull the embroidery unit to the left a couple of inches and to the back a couple of inches. Don't force it if it won't go. Turn on the machine and see if it will reset. If does everything should be okay. If the problem is not solved, it's time for a trip to the Dealer.
sewman7
May 24, 2008 | Sewing Machines
Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Dec 27, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
142 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
