Question about General Electric A735 Digital Camera
Lens error on 7.0 megapixel A735 camera
This error just started how do I get rid of this error?
  • Kimberly Martin
    Kimberly Martin Jan 09, 2009
    I do not have a menu 2
Format camera in menu 2
Posted on Jan 06, 2009
  • cellicini Jan 10, 2009
    press menu, push right arrow, that is set up, scroll down to reset settings push right arrow, enter yes with up arrow, press ok. This will bring the camera back to its factory preset condition. If you still have a problem return it. Be sure dial is set to play back before all this(green arrow)
I cant use the 7.0 megapixel a735 as a camera, MY PC DOESNT EVEN RECOGNIZE IT AS A CAMERA IT THINKS ITS STORAGE WHAT DO I DO?
If you try to use it as webcam, that's not possible. Probably with software from a third-party, you should try it.
Apr 22, 2011 | General Electric A735 Digital Camera
Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 19, 2010 | General Electric A735 Digital Camera
Electric A735 Digital Camera: lens error cant zoom out...
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
May 18, 2010 | General Electric A735 Digital Camera
When cutting on my camera, it saids lens error. i dont know what to do...
This error occured when lens is prevented from properly extending or retracting. When pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed due External shock or liquid, sand & dirt etc. enters the camera.
Avoid applying pressure to the lens and surrounding area:
1) Do not touch Lens while shooting.
2) Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera off and then on again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
Apr 12, 2010 | General Electric A735 Digital Camera
My camera is displaying on the lens WRITE PROTECT on my ge 7.0 megapixel A735
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts protects the card from writing, the position nearest the contacts enables writing. If the switch is already toward the contacts, slide it fully the other way and then back again.
If that doesn't work, try a different card.
Feb 04, 2010 | General Electric A735 Digital Camera
Help ge camera keeps showing lens error a 735
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Nov 21, 2009 | General Electric A735 Digital Camera
LENS ERROR
My daughter had the same problem with her pink A735. I tried removing the batteries, resetting the default settings and every combination of buttons. Finally I grabbed the lens as it was opening and forced it out all the way. There was about 1/8" that it was short of being fully extended. This fixed the camera for at least a while, but it sounds like there is a problem with the mechanism as it clicks every time the lens deploys and retracts now. I suspect this is a short term fix, but if you are planning on tossing the camera out it is worth a try. This camera is only about a month old.
Dec 07, 2008 | General Electric A735 Digital Camera
General Electric A735 Digital Camera Logo
183 people viewed this question
Top General Cameras Experts
JOHN ALBURY
JOHN ALBURY
Are you a General Camera Expert? Answer questions, earn points and help others
