My Ihome dimmer no longer works. I have had it for 2 years now.
  • Anonymous Mar 13, 2009
    Suddenly my "dimmer" is dimmed out -- no lighting behind the clock. I have to turn on the lamp to see what time it is, even during the day!!
Hi I have an iHome alarm clock/radio that has an ejectable outlet for the iPhone/iPod/ etc and after one drop to the floor, the piece that reads iHome broke off and the ejecting piece does not push out by...
sadly this devices are no longer sold
you should try to find a damaged iHome and use for replacements or find a used one to replace your actual device
ihave an iHome too, and i had made some tricks to keep it working
Mar 22, 2011 | Audio Players & Recorders
Radio just hums.
Im having the same problem!!! Trying to figure out if my 6 year old cut the little cord that is attached, inside, next to the line in hole.
Jan 29, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
My cars headlights no longer come on
First Rule Out Fuse And BULBS it took 20 years but I did see BOTH Blow out Same time .
If all is Well there and you Knoe how to test dimmer switch do so and Obviously if dimmer is good Headlight Switch is Bad
Jan 21, 2009 | 2001 Toyota Corolla
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
282 people viewed this question
 Grubhead
Grubhead
