Question about Pentax Cameras
CAMERA STARTS UP AND SHUTS DOWN IMMEDIATELY
I'd appreciate your assistance with my camera problem. Initially I thought that the batteries were depleted. I changed the batteries but the problem persists.
I switch the camera on and it activates as normal. However after a series of short of beeps (within 2 seconds of start up) the camera shuts down.
thank you very much
regards
Graham Rae
  • graham_rae47 Dec 09, 2008
    Many thanks to Benimur.
    I tried his suggestion, but problems still exists.
    Any other suggestions ?
    Many thanks
    Master:
  • 474 Answers
The beeps are usually a message that tells the repair man whats wrong, just like a computer. If you can contact customer support, see if they can tell you what the beep code means and you can go from there.
usually Beeps partain to memory on a computer, not that there the same but if it has a memory card, try removing it and then powering it on. If you can plug it into outlet power, try that as well. The manual that came with it amy have the beep error codes listed as well.
Good luck
Posted on Dec 10, 2008
    Genius:
  • 1,239 Answers
Hi
Now something that will actually help you.
1) the reason this is most likely happening is that the lens is blocked.
If the lens does not extend then it is possible that it has become jammed. Somtimes this can cause the camera to sense an error and shut itself down immediately after powering on. There are other explanations for the behavior, but if the lens does not move this is the most likely cause. If the lens does extend but then the camera shuts right back off it is possible that an inner component such as the focusing element is not functioning properly.
When a camera comes on and then turns right back off it is generally due to some failure in its self-check at power on. Most of these failures come from the lens due to the fact that it contains most of the moving parts.
Check with your manufacturer for warranty support or recalls. Failing that you can find an online repair provider who can fix your camera.
how i fixed this was (I'm not kidding) I hit mine against a card board box. and that dislodged the lens, now it works. you can also just try taking it apart and cleaning it. that gave me an electric shock so be careful.
hope I helped you.
PS "you might need an idiot to do this for you. no kidding."
Posted on Dec 07, 2008
    Genius:
  • 1,550 Answers
Clean the contacts of the battery holder .
Also try to switch on your camera through AC power chord and check whether it is working properly .
If it is not working properly then you need to take your camera to service center to check the internal board for this malfunctioning .
    Sergeant:
  • 399 Answers
The socket where u inmsert the batteries are not cleaned .there is a thin metal element that has to be cleaned properly to detect the batteries.also insert the battery from good company.the local batteries show this problem of quick draining.
  • Pentax Master
  • 13,433 Answers
Hey, what is the brand and model of your camera, a firmware update might fix the problem, if not, it requires service.
You can get a free repair estimate if you are outside of warranty from
www.advancecamera.com/repair
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try to clean the battery contacts. At certain instances it may be necessary to scrape them to remove corrosion. Additionally, they may be required to be bended at a bit (or stretched) so as to ensure that these contacts exert more pressure to the batteries.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 09, 2008
    Hi again,
    Appreciate the update on the developments or to be more exact the lack of it.
    Based on your 2nd post, the best next move would be to seek the services of an authorized service center as all other tries would be pure guesswork, workarounds or temporary remedies especially if the procedures as laid out in the service manual are not followed.
    The temporary workaround may include (but not be limited to):
    • reset should it be available through a small button, menu feature or removing the battery and the memory battery for an extended period of time;
    • jarring the camera back into action by thumping its base/bottom against the palm of one's hand or on the pages of an open book;
    • opening the camera to check for any loose/detached flat cables, connectors or anything out of the ordinary.
    Cheers.
Canon a630 turns on then shuts down
1) press the power button for a moment
2) confirm that memory card is securely closed
3)batteries loaded in wroing directin
4) batteries ARE not the same right type , use only alkaline or NImh
5)insufficiente battery voltage.
6)poot contact between camera and battery terminals.
7) if this DOESNOT resolve the problem you must go to the repair shop service, some short in the SYSCOM and circuit associates are faulty.
God bless you
Sep 22, 2012 | Canon Cameras
I have a Pentax M20 camera. I love the camera but all of a sudden I find that when I turn the camera on, the camera almost instantly shuts off. I have new batteries in the camera. When the camera first...
I am sorry you having that problem, and even more sorry I do not have a solution...On my Pentax Optio M10 batteries rechargeable or fresh alkaline only seem to last about 5-6 pictures before the camera deems them flat without charge and shuts off...it is so annoying I assume yours is possibly doing the same.
I suspect this to be a camera problem, I also notice the camera dos not recognize all rechargeable batteries some of them do not even get acknowledge.
If anyone gets a solution help us both....
Oct 14, 2010 | Pentax Optio M10 Digital Camera
Camera shuts down when 'zoom lens' is used.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
Camera shows batteries need replacing after putting in fresh ones
Try cleaning the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol. If the sticky coke got inside the camera, it will only get worse as the phosphoric acid does more damage.
Dec 08, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
After replacing AA batteries....camera attempts to power up,l but shuts down immediately....
Your problem may be due to defective batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Nikon COOLPIX L10 Digital Camera
Fuji S5000 Shuts down
Battery problem, might need new rechargeable battery as old one can't hold charge no more.
Nov 06, 2008 | Fuji FinePix S5000 Digital Camera
Power going away..
Have you tried stretching the contacts upward to hold the battery more securely?
Jul 23, 2008 | Nikon Coolpix L11 Digital Camera
I turn camera on and it shuts off immediately
I had the exact same problem, it would shut off after trying to turn it on. The door to the memory card has very small tabs on it that push in some kind of sensor inside the camera when you shut the lid. It starts up when I push in the sensor.
Mar 24, 2008 | Fuji FinePix S3000 Digital Camera
Cmaera will not stay on
I had the same problem. After trying several different new batteries I bought high grade Lithium batteries. This worked! Before getting a new camera try spending $15 on quality batteries. It worked for me.
Oct 31, 2007 | Sony Cyber-Shot DSC-W5 Digital Camera
Cameras Logo
24 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
