Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have replaced the gears system in my craftsman 1/2 hp garage door opener. I pushed the button to test the motor and it went up without a hitch. I then went to push the button again and the door went down a foot and the motor kicked it back up. Ten times later, the same thing continued to happen. Nothing looks dislodged or broken and the chain is tight. Please advise...
    Problem Solver:
  • 6 Answers
Can you adjust the down-travel? On mine, it's a white nylon screw, on the left side, inside the light cover. Seems like there were instructions for this adjustment in the instructions for the gear replacement.
Posted on Dec 07, 2008
Craftsman 1/2 hp when you hit button to open the garage door the door stops - you can push the button upto 10x before it will finally open. It's like a fight to get the opener to work
Make sure you don't have a broken door spring. Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is going bad. You will find what looks like white sawdust. You may also need to increase the 'up force.' This is a control on the rear of the motor unit near where all those white wires go. Increase this a bit and try.
Feb 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
1/3 hp liftmaster professional.....wall button pushed.....makes running noise and light comes on.....no door movement
Remove the cover from the motor unit. I'm sure you will find white sawdust all over and the drive gear will be stripped. It is a white nylon gear just in front of the motor. The part number is 41A2817 and comes with instructions. It is available at any door opener service company.
Jun 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP garage door opener that has been working flawlessly until yesterday. The door is closed but when I push the wall button, it raises ~ 2 inches and immediately goes back down. The...
First check the door springs. Most likely you have a broken spring. If not, remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and is likely stripped.
May 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
When I push the button to open my garage door, the
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. It is probably stripped. It is a good time to release the door from the opener and try raising it by hand. Your door springs may be weak or possibly broken.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1\2 hp clicks, motor wurrs for 1 sec', but doesn't open
You have a stripped gear on the opener. Take off the cover on the motor. The bottom of the cover will be filled with white shavings. You can repair this with a "liftmaster gear and sprocket assembly".
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN GARAGE DOOR OPENER PROBLEM
i have a garage door opener craftman 1/2 hp model 13953985 the light is flashing 10 times . now you have too hold down on the button to raise and lower .
Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but gear doesn't turn on my Craftsman 1/2 HP
What did you pay for near gears. curious. often get stripped gears in cold weather as door is frozen down to ground. if possible, kick door bottom edge with heel to break bound if you suspect it is frozen to ground.
Jan 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
76 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
