Question about Singer 7462 Mechanical Sewing Machine
Sewing machine, strange noise
I have a sewing machine and I'm trying to make a blanket, but the needle broke so i put in a new needle in, and ever since then, the sewing machine has been makeing a clunking noise and the thread keeps breaking. What do I do?
  • 57 Answers
Is the needle in right? There is a front and back to a needle. Also is it the right needle for the machine?
Posted on Jan 05, 2009
Why does it make a knocking noise as it sews?
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
May 12, 2016 | Singer Stylist 7258 Electric Sewing...
When sewing I am getting a clicking noise with each stitch. I have change bobbin etc. What is this?
Have you installed a brand-new needle? Usually, a bent or damaged needle will make strange noises. You can probably open the bobbin area and hand-rotate the handwheel and watch the needle action. Could be the needle/hook timing is off and the needle is nicking as it lowers to pick up the bobbin thread.
May 02, 2016 | Brother SE-400 Sewing & Embroidery Machine
I have my machine threaded and it runs with no beeps however it is not sewing the material together
I'm wondering if you have the flat side of the needle in correctly. If your bobbin assembly is in the front of the machine, the flat side should be towards the back. Also, check to make sure your needle is ALL the way up in the needle clamp.
Sep 02, 2014 | Singer Advance 7422 Electronic Sewing...
Clanking noise & won't sew
Are you sure you put the correct type of needle in? Normally, if you have any problem, cleaning and oiling will fix it. It sounds like you either didn't tighten the needle screw or you put the wrong type of needle in.
Jun 24, 2012 | Janome Sewing Machines
What can I use for a blanket stitch on this machine?
A blanket stitch is traditionally done with a large needle and wool to a folded edge of fabric and is often done about 1cm wide, most sewing machines can't swing the needle this wide or take the heavy gauge thread you need for the blanket stitch effect, its a hand done thing.
Apr 14, 2012 | Elna 7200 Computerized Sewing Machine
Machine stopped sewing, needle shuddered and quivered, display screen said to stop could be safety issues, looked at manual, said thread jam or needed new needle, i changed needle there were no jams,
then they didn't not fix the machine,, I suggest to take the machine back to them
& tell them how much you don't appricate it's still doing the same thing.
I've heard of this happening before.
Apr 02, 2012 | Janome Memory Craft 3000
My Janome magnolia is 3 years old. Last week I was sewing and everything jammed, needle went to side and broke. It was trying to run but couldn't. I took bobbin out and cleaned it, oiled everything, where...
Try the process of elimination. Take out the needle, take off the needle plate, take out the bobbin case. Run the machine. Does if run full speed? You might have to let the machine run for about 5 minutes. If it runs slow or you hear it slow down, you might have a bad connecting link between the needle bar and the main shaft counter weight. They seize up sometimes. (Shop Repair).
May 03, 2011 | Sewing Machines
Needle hits the white plastic where the bobbin case sits.
It may be as simple as you didnt get the needle pushed all the way up in the needle bar. Get new package of needles and try a new needle and make *sure* it goes up as far as you can push it. the reason I suggest a new pkg of needles is if one is bad in the pkg, they are probably all bad. If that doesnt fix it then the needle bar timing/height is off and need to be repaired/adjusted by a tech.
May 05, 2010 | Elna 7200 Computerized Sewing Machine
My hobbylock 774 stops sewing...i've listen a plastic cracking...maybe i've broke something? It has all sewing thread strung...can you help me?
The 774 is a very nice serger. Take the needles out and turn the handwheel and listen for the noise. Put two NEW needles in and listen for the sound. If it isn't right, take it to a repair person before the problems escalate.
Sep 30, 2009 | Sewing Machines
Sewing machine
my machine will not sew what do i do??
Jan 23, 2007 | Yamata FY900 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
298 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
