Question about Mitsubishi WS-55909 55" Rear Projection Television
Setting 1080i How do I set the 1080I on my Mitisubishi WS55909 rear projection
Component inputs 1 and 2 will only pass up to 480p. to get 1080i you must use the DTV component input.
Posted on Jan 04, 2009
TV only formats at 480i
Check in your instruction manual to see if the set can actually work in 1080i. Most of the sets going back about 4 to 6 years ago were not capable of working in 1080i.
The signal coming to your Sat box may be in 1080i, but your Sat box has to be able to output 1080i. This can be quickly verified by calling the support for your service and giving them the model number of their Sat box.
Jerry G.
Dec 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Other inputs not working on rear projection toshiba
check for progressive scan and interlaced setting also verify if you have component hook up that it auto maticall chooses your resolution because if your tv is waiting for 1080i and you send 1080p it will not always work and if it expects 1080i and you send it 480i(s-video or rca connection) it may not automatically flip
Apr 14, 2009 | Toshiba 42H81 42" Rear Projection...
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
My ws-65611 always stay in 480i even with HD signal.
If you are using the component connection, make sure you are connected to the one that will support 1080i. If that is not the problem, make sure that the HD receiver is outputting 1080i and not 720p. No RPCRT will support 720p and the video may be down-rezed to 480 since this is the case.
Jan 25, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Cannot change my Mitsubishi WS-55615 to switch from 480 to 1080I
You cannot change the setting on the TV itself. you need to go through the settings on the equiptment you have plugged into the TV to change their settings to display a different resolution.
Sep 15, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Xbox 360 or Dish ViP 622
when i hook either my dish hd receiver up to the 1080i component video inputs, everything works fine if i set either device to 480p, but i get nothing i set them to 1080i.
Apr 09, 2008 | Mitsubishi WS-65869 65" Rear Projection...
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
Cant get 1080i
This TV came out in 1999 and the HDTV standards wern't established yet. Just make sure you are using the DTV YpRpb inputs and not the DVD YpRpb inputs on the back of the set. Leave the menu setting at 480p and on the :"ASSIGN INPUT" sub menu make sure "DTV" is set to YpRpb. Even then it may not be compatible with a PS3 at 1080i.
Sep 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
DVD UPSCAILER 1080i
get a new set of cable and try again if nothing then you will have to get a tech to check your set good luck.
Jun 04, 2007 | Mitsubishi WS-55613 55" Rear Projection...
HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Dec 30, 2006 | Mitsubishi WS-55857 55" Rear Projection...
Open Questions:
Mitsubishi 55" big screen TV powers down after 70 secs We had a power outage in the neighborhood, after which our Mitsubishi 1080 HDTV WS-55909 only had a blinking green light on the front (no variation or pattern), even after the set was powered down. Upon reading online, it appeared the DM module capacitors were the likely culprit, so I sourced (7)1000 microfarad capacitors and replaced them, then reassembled the TV. This was the first time I'd soldered on a circuit board, so of course a lot of things might have gone wrong. However, after that the TV now powers up, but I only have a blue screen and cannot get the remote to work except to power the TV on and off (tried changing batteries in remote, reprogramming remote per setup manual, etc). Further, the TV powers off after 1 min and 15-20 seconds. I then tried to see if I could get any of the attached devices to work on their own with no other devices on except the TV. Each of them yielded a blue screen (X-Box, VCR/DVD recorder, Wii, cable) except the DVD player -- which displayed a great picture! The problem is the DVD will play 1 min 15 seconds then the TV will shut down and the green light will blink steadily (no pattern) for 60 seconds, then power down. And this only works if the DVD is on before the TV is turned on, and since the remote doesn't work I have to press "play" on the DVD player. The DVD is hooked to Component Input 2 so that input appears to be working fine. The VCR/DVD recorder is attached to Component Input 1. When I had it powered up and turned on the TV, I got a blue screen. However, when I left the VCR/DVD on and then turned on the DVD, there were jagged lines on the TV for 3-5 seconds, then the TV made a popping sound and shut off. When I then turned on the TV (i.e., with both the VCR/DVD and the DVD on first), the DVD worked but could not switch to the VCR/DVD without the TV turning off. I also tried switching the cabling for the DVD to Component Input 1, but the DVD no longer worked. When I tried the VCR/DVD on Component Input 2, it still only yielded a blue screen. So is Component Input 1 bad? And why would the TV work with the DVD in Component Input 2 but not the VCR/DVD? Obviously I have multiple problems here. The first one to deal with is the TV shutting off after 1.25 minutes. I am unable to see where I can get an error code when the blinking light just blinks quickly without any pattern, and neither the front panel controls nor the remote control work. Perhaps most of my inputs on the rear of the TV don't work now except Component Input 2 but I don't know how to test this. So I made a little headway with the capacitor replacements, but not sure what I can do at this point. Any suggestions? I've seen references for other Mitsubishi big screens that shut down like this, and the fix was related to the output power module, but not sure if it applies the the WS-55909. Thanks in advance for any help you can provide. estout7
Jun 28, 2012 | Mitsubishi WS-55909 55" Rear Projection...
See all Mitsubishi WS-55909 55" Rear Projection Television Questions
Mitsubishi WS-55909 55" Rear Projection Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
