Question about Toshiba 35A44 35" TV
Stuck in demo mode
I'm pretty sure my television is tuck on demo mode. It was working fine then one day it just started doing this thing where it flips through all the inputs and now the remote doesn't work either. What should I do? We are also stuck in the demo mode and it is not responding to the remote. We have tries new batteries in the remote or the buttons on the front panel.
    Genius:
  • 1,239 Answers
HI
you CAN fix it by doing a reset on the base of the device.  use  a paperclip to push the button. Hope this helps!
Posted on Dec 07, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    press that button for 3osec..if that dosnt work
    press all the buttons on the tv at the same time and the tv reset itself....
    Genius:
  • 1,124 Answers
After you did that operation, probably the tv was set into another function. Be sure that in the remote the switch is selected "tv" go to menu and set the tv to the default values.
    Genius:
  • 1,061 Answers
GO BACK AND RESET-UP THE TV.REPROGRAM CHANNELS.IF ON CABLE. MAKE SURE YOUR BOX IS NOT THE PROBLEM.STILL NOT WORKING CONTACT TOSHIBA .COM IF I MAY HELP FURTHER CONTACT.RICHARDM69
  • Desktopsbyduck-Computers
    Genius:
  • 1,011 Answers
Sir,
It requires two buttons to be pushed at the same time to knock it out of the demo mode.
Try pressing the up and down volumes at the same time. If that does not do it, try one of the volume buttons and the power buttons.
Also, some of them will go out of demo mode when they are reset. Reset is done by unplugging the power cord for 4 hours, then powering up again.
Hope this helps.
PS: On some sets the buttons on the front of the set must be used, not the remote control
  • 4,472 Answers
It sounds like you will need to contact toshiba as you have a more serious problem. If resetting the tv doesn't work I would advise either contacting toshiba here:
http://www.tacp.toshiba.com/customersupport/contact.asp
or contacting a toshiba service center and inquiring about an estimate here:
http://www.tacp.toshiba.com/customersupport/service_center.asp
Please take a moment to accept and rate my solution accordingly.
Thank you and have a great day,
Lee
  • 10,594 Answers
Please unplug tv from ac outlet and replug after 5-7 minutes and check.
Problem still exist, let me know exact model number to help you out.
    Genius:
  • 1,550 Answers
Unplug your television for 2 hours from power chord and plug back the power chord to tv and then hold together the menu and the vol+.then press the power on,when its on release together the menu and the vol+ buttons.
Hope this helps .
If your problem is still not solved call technican from Toshiba as it tends to be a problem in Control board
Sony mhc-gx555 stereo systeme put demo mode off
Pretty sure you just press the display button repeatedly to shut it off, but here is the manual just in case I missed it:
https://docs.sony.com/release//MHC-GX255_GX355_GX555_RG575S_RG475S_RG470_RG270_RG170.pdf
Jan 25, 2017 | Sony Car Audio & Video
Just bought a car with this stereo. Was working fine and then I accidentally was messing around trying to figure things out and put it in demo mode. Now it's stuck!! Can someone please help?!?!
With the stereo on, hold the large round button in to get to setting menu. When it gets to that, I believe clock adjust comes up first, just turn the knob to get to demo mode and then push the button in. Turn the knob to switch demo off and then push it again. That should do it.
Jan 10, 2017 | Car Audio & Video
GE Dryer GTDP520EDWW does not start
and you have tried other drying types? Normal, Permenant Press, ect...?
Apr 10, 2013 | GE GTDP520EDWW 7.0 Cu. Ft. Electric Dryer...
42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
May 19, 2009 | LG 50PC1DR 50 in. Plasma HDTV
Stuck in demo mode
I had the same problem. Was told to unplug the set for 1 minute but it still was stuck in menu screen scrolling. So I was told to unplug the TV for 4 hours, it resets it I guess because it worked! Try it!
Nov 19, 2008 | Toshiba 35A44 35" TV
TV STUCK IN "DEMO MODE"
I had the same problem with my TV, This is the way i fixed the problem i took a hammer and banged on the menu button a few times and know the tv works great!!!. Little weird huh:)
Jul 28, 2008 | Toshiba 35A44 35" TV
My Maganavox #19PSC5 0121 19''
I just found a solution elsewhere on this site...
In order to make the Demo Mode stop, you should press Volume Up and Channel Up together, and hold for four seconds. This worked for my mom's tv, I hope it works for you, mooone (and everyone else, too).
Jun 01, 2008 | Philips Magnavox 20MS3442 20" TV
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Jan 03, 2008 | Televison & Video
Demo mode wont shut off
I have this same problem, just started 2 days ago. Changed batteries in remote and everything - driving me nuts- now i cannot change channel or adjust volume! I powered off TV, took batteries out of remote, turned back on and now still stuck. I think we bought junk!
May 21, 2007 | Toshiba 32A33 32" TV
Toshiba 35A44 35" TV Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
