Kenwood kMix BLX50 Blender, White Logo
A
Anonymous Posted on Jul 02, 2012
Kenwood kmix blx50 will not work believe liquid has entered system.fuse has been checked,any advise?
How do I disassemble a Kenwood KMix hand blender model HB894? Does anybody have some service manual? Any disassemble diagram?
There is a name plate, it is glued on so you need to prise it off. Underneath is a tab - press it along with the other two on the side and the motor assembly slides out.
Want a seal for kenwood blender model bl300
That kenwood is a UK model so if your in the US it's tough to source. The ring you need should have an outside diameter of 76 mm and an inside diamete of 56 mm.
This is a uk ebay link with the exact part.
1 Kenwood BL300 Blender Liquidiser Rubber Seal Gasket
This is a us amazon link with something that might work but not exact. There is a uk amazon equivalent if that works better for you.
Amazon com kenwood blender seal
How to
I would suggest just replacing it. It can become a shock hazard in its current conditon.
What can I do about my Vita-Mix Blender which leaks at the bottom?
You will need a special wrench to remove blade assembly.
then the gasket/seal is inexpensive.
you can check here:
Contact Us Customer Service Vitamix
or check here:
Vitamix Wrench
How to dismantle hand blender kenwood kmix?
hi there, i have one of these and am quite tech savvy and want open
the sucker up and see whats wrong. Just would rather open it with
minimum damage to the casing.
Is there a way i can private message you my email address?
thanks
Dan
Burning smell in the container and outside when in use
Seal under blade Assembly, on shaft leaks, allows liquid to enter bearing, which then fails, creates heat and overheats rubber, thus the smell. Bearing and seal must be replaced.
Top Kenwood Blenders Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
ADMIN Eric
ADMIN Eric
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
