Question about Samsung DVD-P144 DVD Player
Resetting video out settings
I have selected the components out setting for video instead of the s-video n now i dont get the menu on my screen.. i get no options on my do i reset to factory settings(to get the output back to s-video)
  • 3130 Answers
SOURCE: samsung dvd player p243
Your going to need to read the owners manual as its in there If you dont have one go to
Posted on Jul 25, 2006
0 characters
1 Points
My screen is cracked where can i get it fixed
see the cause and fix it:
1er alternative:
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
  3. Try a direct connection from the DVD player to the TV set, instead of via other components.
  4. 2nd alternative:
  5. Enter Setup and then Player menu to select the correct screen format.
  6. Select the screen format from the DVD disc menu or press zoom key.
Jul 21, 2012 | Mintek MDP-1810 Portable DVD Player
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
By mistake, I selected RGB connection while setting up in sony DVD NS730P. Now the screen goes blank means output switched from DVD component connection to RGB port. How to return back to DVD componeent...
Please press the DISPLAY when the player is in stop mode.
The Control Menu appears.
Press the up/down arrow to select SETUP, then press ENTER.
Press the up/down arrow to select the RESET and then select Yes from following message.
Press ENTER.
It will reset the player.
Jan 13, 2011 | Sony DVP-NS730P DVD Player
My son selected the out put to 1080p instead of 1080i and is giving me a message invalid format, and i can not reset it to the 1080i, i got a samsung BD-P1200
Hi there.
Take out any disc still in the player and, with the power on, press and hold down the Fast Forward button on the front of the unit for 10-15 seconds. This will reset your player to its default settings. A language menu selection should appear on the TV screen, which confirms the reset.
Keep in mind that the default output for the device might be analog, so make sure you have those connectors at hand.
Hope this helps,
Feb 24, 2010 | Samsung BD-P1200 Blu-Ray Disc Player
Sony BDP-S350 - made a mistake in setup, cant get a signal
Just had this problem,this is the button config for master reset when you have no picture: Left Button x 3 Down Button x 7 OK (Centre Button) OK (Centre Button) Down Button x 6 OK (Centre Button) Left Button x 1 OK (Centre Button) OK (Centre Button) Wait a few seconds for settings to complete, then switch off. When you switch back on, you should have a picture and be back at the language setting. Hope this is of some use.
Apr 24, 2009 | Sony BDP-S350 Blu-Ray Player
Setup menu selected entered component under VIDEO
I was able to read a couple of words on the menu screen and with the help of them manual I was able to figure out how to navigate to the default button and was able to reset.
Nov 24, 2008 | Toshiba SD-3990 DVD Player
Picture from analog tv signal is not sharp
I have this same machine, you did'nt mention what input you are using (composite, S-Video, component or HDMI) or what type of display you have (CRT, LCD, Plasma etc.).
If your T.V. has a HDMI input I recommend using that, if not and it's of fairly recent vintage use the component inputs (not to be confused with composite video inputs, or yellow RCA-type input).or at the very least use the S-Video input.
In the setup menu (on screen) try setting the "TV Screen" option to the 480p setting and if you are using the HDMI input try setting that to the highest resolution your T.V. has or set it to "Auto"
Finally in the on screen video menu select the "Video" setting and set the "Still Mode" option to automatic, and the "Output Level" to lighter or darker whatever your preference is.
Remember...Always use HDMI or component video inputs on your television (if it has those inputs)!
Hope this helps!
Nov 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
HELP - Samsung DVD player P347
From the manual...
Connect the DVD to the TV via S-video or Video outputs (not component video) and...
• Press power on from a cold start with no disc in the unit. Press the
SEARCH/SKIP ( ) button on the front panel for 1 second.
The SELECT MENU LANGUAGE display will appear.
Select the number button of the desired language.
regards, Glenn
keraurus (at)
May 17, 2008 | Samsung DVD & Blu-Ray Players
Pinoeer DVD-366
Hi there, just got that progresive problem gone :D
- Startup ur DVD (ON)
- Wait until Loading - No Disc (status on DVD display)
- In here, ur screen still blank (black screen)
And here's how:
- Press "Home Menu" button
on ur DVD (it should be on the down left of the circle button)
-- Watch out, the screen still in blank, just feel it right ok?
- Down 2x -- Initial Setting
- Menu / Ok (the circle button)
- Down -- Video Out
- Menu / Ok
- Down -- Component Out
- Menu / Ok
- Down -- It will choose Interlace, it will saved the day :-)
- Menu / Ok
That's it.. Cheers mate ^^
Give me a mail if u still have the problem, coz I Know how it sucks.
Dec 02, 2007 | Pioneer DV-366K DVD Player
Mom was hitting buttons and now DVD plays Blue and White!
I think your mom changed the DVD output setting. Using the remote, go to the Setup Menu, then select DVD Setup. Scroll down to the Alt Video Out option. It will either be set to "Component", S-Video, or "Off". It needs to be set to the type output you are using to go from your Go Video deck to your TV. If you are using an S-Video cable, then set it to "S-Video", if using Component cables (Red, Blue, and Green cables), then set to "Component". Otherwise it should be set to "Off".
Hope this helps.
Nov 26, 2006 | GoVideo DVR4000 DVD Player/VCR
Samsung DVD-P144 DVD Player Logo
19 people viewed this question
Top Samsung DVD & Blu-Ray Players Experts
Are you a Samsung DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
