Computer wont power up eve though it getting power
Hi my computer wont power up when i push the power button. The power pack lights up and i know the mother board is getting power because when i move the 9 pin end of the power switch down a few knotches it makes the light come on the power switch. Could my motherboard be blown or my processor or the 9 pin socket on the board?
  • James Calvert Dec 08, 2008
    i changed the computer case over to a new one and found that the power supply didnt work and the case didnt work so put it back in the old case and found i had the same problem that it would power up. The power supply on my old case is definetly working and the motherboard is getting power im wondering if it is damaged. Also now i have noticed that the power lead i used for the new case has stopped working also so maybe there has been a blow out and its screwed my components?
Hi i am enver parson a FixYa technician can you tell me if you have reasently changed any of your pc components and if you did wot was it
Posted on Dec 07, 2008
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
Desperate to get my Dead Desktop going again................
I always start with the power supply. Your power supply may not be producing all the power your motherboard is requesting, even though the light on the back is on. If you dont have a power supply tester, then you can try removing your power supply and trying a known working supply in it, making sure you have the right connectors on it for your motherboard..
I looked at a pic of your motherboard Asus A8n-vm and I dont see an orange (or any) button to push. Was that to reset your bios? If so, unplug the system from the wall, and carefully remove the battery from the motherboard. While it is out, push the power button on the front of the computer a few times. The computer wont start up, as you have it unplugged, its just to drain the motherboard of power to reset the bios. Then reinstall the battery, making sure it goes in the same as it came out (- is usually down and + is up). This should reset the bios info to the factory settings.But I still think it is a faulty power supply.
Feb 03, 2013 | HP Pavilion a1520n PC Desktop
Hi i have a 2001 s10 the 3 rd brake light is working but the side brake light arent - side lights come on checked fuses heeeelllpp
Found this problem on a few Blazers and S-10s . Try pushing the hazard button in and out a dozen or so times then turn them off and check brake lights. The brake light circuit runs though the turn signal switch and hazard switch. Contacts get dirty and wont let power get through. Hope it works for you!
Dec 04, 2010 | Chevrolet Chevy Cars & Trucks
Power wont come on
Either the power supply has a loose connection or is faulty.
You can try removing the battery pack, press and hold power button for 3 seconds and then put battery back in and see if it corrects the problem. You can test power output from the supply to see if it is putting out the voltage it states it should on the label of supply.
Nov 23, 2009 | Computers & Internet
I push the on button and nothing happens. is it
Even though a lot of things might have gone wrong and caused this, especially if where you place the System is not well ventilated, and the CPU becomes very hot, it shuts down automatically...and you will have to wait for a few moments, get a cool environment and power it on. but I will also try and tell you some troubleshooting steps that you can try.
Since you have already checked the power source and all is Ok, then try this out:
Disconnect your PowerPack(Power Supply Unit) from the CPU and try to power your PC with another Power Pack (Power Supply Unit), that you are very sure is working.
If it powers up, then just get a new Power Pack(Power Supply Unit) for system.
If you cant do this yourself, just get a good technician to do it for you.
Try this first and let me know how it goes, so as to know the next step.
Hope this helps.
Nov 21, 2009 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
My gateway laptop will not turn on when you push power button.
If you power it on and get the light it means either two things:
1. It needs a minimal charge on the battery to power. ( havent seen this since the old Compaq/Apple stuff ) or
2. The motherboard is fried. ( Just diagnosed a HPDV6000r special edition with this beautiful computer, dead motherboard ).
What is the warranty like:
NOTE TO ALL STUDENTS: Buy New laptops in November, so the warranty comes up in October, after you know you need more computer or repairs!
Oct 03, 2009 | Gateway ML3706 Notebook
Laptop will not turn on
Hi, this indicates to me that you have a low battery and the power pack is not functioning resulting in not enough power to boot the computer up.
A replacement power pack will fix your problem.
Regards mistyman
Aug 14, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
415 people viewed this question
David Payne
David Payne
