Question about Memorex MT1701 17 in. HD-Ready LCD Television
Memorex MT 1701 Screen Problem
When the power is turned on the screen turns off after a second. I tried to open it to check for shorts but was un able to open it. Let me know what you think the problem is before I try again. Thanks.
  • 3 more comments
  • Arturo366 Nov 03, 2007
    I bought a Memorex MT1701 17 and I get the green LED to go on but that is all I get, I opened it up and I found the the highvoltage leads from inverter have no power. Please advise.
    Arturo366@codetel.net.do
    Thank you
  • almost_junk Jan 16, 2008
    Have same problem. comes on for a second then shuts down. Found 3 of the 1000mf 16v caps on the inverter board leaking. Replaced them but still not working. Need schmetic.
  • mikebad Feb 18, 2008
    same problem, picture comes on for a second and then it goes away but the audio stays.
  • Anonymous Nov 22, 2008
    when i turn it on stays on for awile than shuts off then turns on by itself
  • hamadina1111 Feb 09, 2009
    i do have the same problem please please can any one help!! i tryed evrything,I tried to change all capacetors or keep it on with tv mode with sound on and i put a heater for it but still dont work, please some one must know how,where are you??
    my e-mail is hamadina1111@yahoo.com
    thank you in advance.
    Problem Solver:
  • 12 Answers
Ok for those of you having the problem with the memorex mt1701 lcd tv / pc monitor well i had got one of a site call cl anyway when i first turn on it would stay on then turn off all i could here was the sound ok well i figuerd for sume reason the pc mode is the only way to get it to work right!! dont ask me y? but heres how to keep it on and able to watch tv. ok first when you turn the tv on it will go blank after a few when it does on your remote turn it to pc mode that will b the next one after tv you won be able to see if its in pc mode unless you turn the tv on and off a few time but you dont need to do that cuz pc mode is right after tv mode ok so your in pc mode you still wont see anything but what you want to watch for is the the power light it will remaine green for a few seconds than change orange when it does turn off tv than power on in pc mode you will see a no signal sign blinking swithch to the next mode quikly before the light goes orange again after this youll be able to watch tv but keep in mind iv had to youse this methode every once in awile. sumtimes whe id turn the tv of and on it would go to the blank screen again and sumtimes not so i hope i helped sum of you with this problem but thats the way this tv works for sum reason if you have any questions feel free to ask thanks and i hope this help you!!!!!!!!!
Posted on Dec 06, 2008
I was having this same problem and it seemed to always happen on cold days!! Happend about three months ago and the tv did not work for three days...just happend again this morning. All you have to do to fix it is to leave the tv turned on for about 15-20 minutes with just the sound working. Than turn the tv off and back on and it should work. You may also cover with blanket during process to speed it up. Do this whenever needed as it should only happen during colder months or if you have a/c in house turned on really high. I myself have a room in the basement where it stays cooler..add in the snowy weather we have been getting and it is no wonder the tv was too cold.
This problem does not just consume the memorex brand but just about all of the flat panel tvs.. Televisions with longer times between uses are more supceptible.
Hope this helps!!
Posted on Jan 08, 2009
    Problem Solver:
  • 4 Answers
I had a similar power issue with this model.I opened it up and took the metal houseing off the cicuit board.Somehow it was shorting the tv out.I left it off and it has worked for 1 yr 5 mnths so far.
Posted on Nov 29, 2007
Closed captioning will not turn off on Memorex MT 2025D. I have tried everything and it shows CC as "OFF" in the menu but it is STILL on. Any suggestions? This is driving me crazy!
This maybe a powerline glitch. Reset the TV may help. Disconnect TV from powerline for 5 minutes, then reconnect and power on?
Sep 01, 2010 | Memorex MT2025D TV
Memorex mlt3221. white screen, no sound, no function.
Check the power supply module for bad DC filter caps first, then check the backlight inverter board for shorts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Jul 29, 2010 | Memorex MLT3221 32 in. LCD TV
Compaq 1701 monitor blank screen
If you plan to DIY repair, please read below and look at the pictures so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 22, 2010 | HP Compaq 1701 17" LCD Monitor
Memorex mvdp 1085 dvd player, says door open.
our memorex 1085 doesnt play it just buzzes and has a blue screen
Jan 09, 2010 | Memorex Televison & Video
I turn on light and screen dosen'tcome up?
try buy new battery or use power source while openning it to make sure the battery is not problem ^_^
Jul 08, 2009 | Video Game Consoles & Games
Memorex MVD 2042 DVD Player ''Key Lock on''
mt memorex dvd player says ``key lock on´´ and i don't know how to quit that and i can't opened with the remot control
Help please!!!!!
Nov 17, 2008 | Memorex MVD2037
Can't get time and day display off screen
With the MT1192 Memorex set, it's the RECALL button on the remote that toggles it on and off the screen.
Nov 11, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
I HAVE A MEMOREX (MMP8640A) AND IT WON'T COME ON.
reinstall the firmware, following the next steps:
Download the firmware from Memorex site (www.memorex.com) but use the firmware for MMP8620 NOT the one for MMP8640, otherwise you will finish with your player starting with a blank screen.
FIRMWARE UPDATE INSTRUCTIONS FOR MMP8640.
1. Make sure the unit is powered off.
2. Plug one end of the USB cable into the USB port on your PC.
3. Click on the start button on the lower left hand corner on you PC.
4. Highlight Programs, on the drop down page highlight Memorex Aptitude Digital Audio Player.
5. On the drop down window click on “Memorex Aptitude Firmware Download”.
6. Memorex Aptitude Firmware Download Window will open with a notice “PLEASE CONNECT
DEVICE”.
7. Press and hold down the MENU button on the MP3 player at the same time connect the other end of the
USB cable to the USB port on the player.
8. Firmware Download Window will begin initializing.
9. Keep holding down the MENU button on the player until the Firmware Download Window displays
“READY”.
10. Release your finger from the MENU button.
11. In the Firmware Download Window, put a check mark beside Format Data Area.
12. Click on the START button in the Memorex Aptitude Download window.
13. Wait until the screen says “firmware download complete”.
14. Click on the CLOSE button.
15. Disconnect the USB cable from the player. The player will turn on by itself. If the player doesn’t turn
on automatically, press the power button.
Please note if an ERROR message appears on the display of the player when the player powers on, you
need to repeat steps 1 - 15.
WARNING: DO NOT INTERUPT FIRMWARE DOWNLOAD PROCEDURE
Hope it helps, I solve the problem just like this.
Jan 08, 2008 | Memorex MMP8565 MP3 Player
Memorex MT1701 17 in. HD-Ready LCD Television Logo
475 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
