Question about HP Pavilion ze2000 Notebook
HP Ze2000 laptop charger overheats
The charger gets very hot while charging and has started to melt the tip of the charger. i got a new charger and battery but still have the same problem. I don't want it to keep overheating but don't know what to do about it.
  • 20 Answers
CHECK THE POWER OUTPUT RATING ON YOUR POWER SUPPLY AND SEE IF IT IS HIGHER THAN THE COMPUTERS POWER RATING, THIS INFO IS ON BOTH THE LABELS OF THE COMPUTER AND SUPPLY, IF ONE IS HIGHER THAN THE OTHER THAT WOULD EXPLAIN THE OVERHEAT, IF THAT IS NOT THE CASE, THEN GO TO ACERS TROUBLESHOOTERS WEBSITE OR CONTACT THEM DIRECTLY FOR HELP... JON T
Posted on Dec 07, 2008
Why is my charger getting hot after four hours charge
when possible ring the technician up and ask that question
if the charger is old
getting hot would be possible to overheat on new batteries
also it is possible the new batteries are fully charged before the 8 hours
if you have a volt meter handy or know someone who has one
you could check the new battery's voltage
if battery's need more charge
wait till charger cools .. re start the charge sequence
Oct 14, 2016 | Health & Beauty
My samsung laptop charger gets hot and starts to melt when pluged in and powered up and does the same if i take the battery out please helptried a new battery and new charger could it be the jack on the...
I'm unclear however
Does the new charger get too hot? If so the problem is not the charger or the socket.
Does the laptop work with the new charger plugged in but no battery? If so the socket on the laptop is probably ok
Is the actual charger melting or is it just the plug that goes in the laptop that's getting hot, if it is the plug on both chargers then the socket will need repairing or resoldering, they are a weak point, the soldered pins go high resistance and can generate a lot of heat around the plug and socket. Its usually obvious if the socket is faulty because as you move the plug it makes contact intermittently.
DONT USE THE CHARGER THAT'S MELTING and if both are getting hot have the socket repaired.
If only the one charger getting hot the short is probably in the plug on that charger but read on
On a different note the genuine chargers should be over current protected and overheat protected, they should never melt.
May 13, 2014 | Samsung Rv511 Series Laptop Intel I-core...
I HAVE HP PAVILION ZE2000 and being drain for 2 years because the charger ooze smoke 2 years ago but after it ooze smoke we disconnect it then the laptop is still working properly. Then yesteeday, Im...
no 2014 is not today its 2017. why say that.?
if he cant do his job then fire him or find another or retire this PC.
a REAL tech can in fact find a shorted module inside.!!
if worth 1 gram of salt.?
he sounds like a bit fiddler, plays about then throws up hands.
the main power in the PC is shorted.
to find that would take me 1 to 2 hours labor. (upto)
why would anyone spend cash like that on this relic,
Dump all Compaq in the trash and move on... .
let me see, i do the labor and its $200 labor, then a used mOBO is
$150 and now its 20o+150+ 100 more to finish. the job.
why?
ever heard of walmart.?
almost new. and W10 on board. live is good, YOU DO HAVE CHOICES and PC's are in GLUT STATUS NOW>
no need for $1000 for laptop that breaks in half at the slightest bump. (spectre, bs)
behold, DEALS, (this is not spam, i never spam its a DEAL)
https://www.walmart.com/search/?cat_id=0&page=1&query=refurbished+PC&sort=price_low#searchProductResult
why in the world own any COMPAQ? (as McCoy said it's dead Jim)
unless the last ones ever made,maybe, hah,,,,,,
its 12 years old, now. wow.
hey Goodwill store sells em for $20 , yah, or $3 if dead..... we can bury you in dead Compaq.. can. (for fun, sure)
case in point my poor neighbor called GEEKSxxxxd and they charged her $300 to tighten the VGA jack. (Imagine fixing hard cases)??????? bust a VISA ? Cap it?
why do that. why o why? spend real money on DEAD RELICs.
we killed XP if only now, we can , kill COmpaq's
sorry , for the rant.
May 24, 2017 | Compaq HP 418445-001 PAVILLION ZE2000 AMD...
My samsung RV511 laptop seems to be overheating a lot. Whenever the computer is under a heavy load it just shuts off. I bought 2 different cooling mats and they do not help. It is to the point now that...
Check the cooling fan at the bottem of the laptop see if is working ,also use a can of compressed air and blow out the fan give it a thorough cleaning if need you might have to replace the fan .If you will supply me with a model number I will get instructions on how to disassemble to put in a new fan
Sep 07, 2011 | Computers & Internet
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Charger overheating and melting the tip, Irregular charging
First, Check for damage (frays, tears, melting, or cracks in/on the insulation) on the power unit from tip to wall socket. If all looks well then I would check the voltage on the power unit by using a voltmeter. If it's within manufacturer printings on the box, then you might have a possible short.
Hope this helps.
Oct 13, 2008 | Compaq Presario M2000 Notebook
Hp laptop charger is hot!!!!
it just happened to me it got over hearted and the fan in it is brunt wich make the noice u have to get a new one
May 25, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion ze2000 Notebook Logo
238 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
