Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-51HW40 I have 4+ year old Sony KP-51HW40 to which we recently had some work done by repairing some parts on the convergance board (pic appeared 3D). Fewdays after being fixed by technician for the convergance problem another problem appeared. TV shuts down by itself. After turning the power on the screen appears blue then turns black and the TV turns off by itself, all within 5 -10 seconds time frame. I have noticed that the power indicator light in the front blinks around 8 times followed by a pause. Any soultions? Thanks
Unfortunalty I'm not sure how to resolve you current problem. It appears I'm following in your foot steps with the convergence issue (image appears in 3d). I would really appreciate knowing how you resolved this issue (including cost) and if the two issues are related. good luck
Posted on Apr 29, 2007
I read it online that this is a very simple problem. It needs highvoltage splitter. I tried to open the front panel to see where the splitter is. However, I need some hint as to how to open the front panel. Good luck. Kiran
Posted on Apr 07, 2007
Sony KP51WS510 seven years old - have double image.
Ur tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair by replacing 2 STK convergence ICS and some or all of it resistors too.To fixed tv 3D or misalignments R,G,B colors lines tv picture.Are u willing to put in another like $300-350 for tv shops to fixed?That what it will cost for parts and labors by a professional tv tech. to do the job wright.
Jun 12, 2011 | Sony KP-57WS500 57" Rear Projection...
We own a Sony Sony kp-53xbr4ct and recently the image on the screen began to look like a 3d picture with red and green colors. Some research on our end points to a convergence problem. My question is...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 12, 2011 | Sony KP-53XBR4CT 53 in. Rear Projection...
I have a Sony KP-51ws510 that has wavey or fuzzy corners opposite of one another?
The problems ur tv having it is call a convergence problems,it dead.Very common problems,for old DLP tvs design.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than tv covergence board is dead.Tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Sony KP-51WS510 51" Rear Projection...
My television is only 6 years old. Red lines have appeared in the form of a wave pattern on the screen. What does this mean?
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have a colors shadows or 3D pictures look alike?Ur tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 27, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
It appears to be a convergence problem with the colors of the print and images not lined up giving it a 3D appearance.
Will,than ur tv convergence board,must take out and replaced it 2 STK convergence ICS and some or all of it resistors.U have all the requirement tools and can do basic soldering?Yes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit and repair the convergence problems,it ur self.Or the shop,will cost u like $300-350 for parts and labors.
Nov 05, 2010 | Sony KP-51WS500 51" Rear Projection...
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-65WV600 Convergence AD Board
It should be a 4.7 OHM if its under the heatsink near the convergence chips.
You can do the repair yourself using the following instructions.
Feb 22, 2009 | Sony KP-65WV600 65" Rear Projection...
SONY KP 413SU
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Dec 06, 2007 | Sony KP-41T65 41" Rear Projection...
KP-51HW40 - Picture not Clear
Your problem is a typical convergence problem that happens on almost every tube type projection TV set ever built. There are two Convergence amp IC's that need to be replaced. If you have no TV repair experience, play it safe and call in a pro to assist you in this. Good Luck
Apr 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
212 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
