Hi, I have a HPC4180 all in one printer. Basically it will not power up. The Led light flashed on & off when it is plugged in but will not come back on when the on/off button is pressed. Is there an issues with the buttons sticking on this printer. It is fairly new and has not done much work at all. Regards Schubi
  • nick_1962 Dec 08, 2008
    Thanks jon for your reply.
    The HP technition on line said it could be the power adaptor as it does not appear to get warm when plugged in to the wall socket.
    I chatted to him on line after posted thge problem on here.
    going to purchase a new power adaptor will let you how i get on
    regards schubi
  • 20 Answers
THE POWER BUTTON IS FRAGGED, UNLESS YOU WANT TO SEND IT IN TO HP TO GET IT SERVICED, THIS IS SOMETHING UNFORTUNATELY YOU CANNOT DO YOURSELF, JON T
Posted on Dec 07, 2008
  • JON T
    JON T Dec 09, 2008
    i was glad to help man, jon t
Printer error 5200
Well it seems like the waste ink pad error. You can override it but it will need changing or the printer will leak ink from the pad eventually.It needs a service now and the waste ink pad changing but you can reset it yourself by following some simple steps -
1. Plug in the power cord of printer.
2. Press Resume button 2 seconds then press the power button until the green light on (when pressing the power button, Resume button).
3. Then release the resume button, but do not release the power button.
4. While the power button is still pressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange.
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow green.
7. And the computer will detect new hardware, just ignore
8. Press the power button again then the printer will flash.
Check your printer again now it's ready.
Regards
May 07, 2012 | Canon PIXMA MP610 InkJet Printer
How can i fix error 5200 on my canon pixma ip2770
You can try the following 1. Turn off printer, cable power still plug in,
2. Press Resume Button don't release
3. Press Power Button don't release and than release Resume Buttons
4. Press Resume Button 6X
5. Turn off printer cable power still plug in
6. Turn on printer again, now this printer ready to use.
Or try
1. The printer is turned off and plugged the power cord.
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Jul 27, 2011 | Canon Office Equipment & Supplies
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
All three lights are flashing on my HP Deskjet 6127. I tried unplugging it from the power source and then plugging it back in. When I try to turn it on all three lights flash and it won't turn off with out...
Hi
The HP Deskjet 6127 has four buttons and three lights on the front panel
Flashing lights on the printer indicate the status of the printer
When all the lights are flashing, the printer may need to be restarted
try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
2nd press the power button to turn off the printer and hold it down.
Good luck
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Regards,
May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
All LED lights flashing
I read somewhere else over the net and the solution I found worked like a charm: just plug it back on and wait about 10-15 minutes.
Apr 12, 2008 | Brother HL 5250DN Laser Printer
32 people viewed this question
jasbo
jasbo
