My DVD player suddenly stopped working the open & close disk tray does not open Model DRC257N bought April 2006. Had no problem until I moved it to another area.
  • 2 more comments
  • kazzyblue Dec 08, 2008
    My DVD player does come on and the window shows Hello and that is as far as I can go. I have opend it up and there is no DVD stuck in the tray and I do not notice any loose wires - don' t know how to manually push the tray out to see if it will go back in when I press the button
    My DVD player does switch on as Hello appears in the window and that is as far as it goes. I have taken the cover off and do not see any loose wires etc. Cannot find a way to manually open the tray to see if it will open and then see if it will close when the button is pressed
    What ever a spindle motor or controller are (What causes this problem) is it worth having it repaired or consider buying a new one?
    my whole question was not answered - I am a senior on a small fixed income and don't want to pay out money if I don't need to.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, reset your RCA DRC257N unit, that is unplug from the mains for an extended period. Should that be not corrective, then it would require a bit of electronic work on the Power Supply Board. Often the filter capacitor (C411, 1000uF 16V) would require replacement. A faulty capacitor allows a dirty DC to be supplied to the logic/controller circuitry which prevents the firmware in initializing the unit fully.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 08, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 10,594 Answers
Sled motor of optical lens is got stuck so get hello and nothing more.
Unplug unit from ac outlet, take out its top cover and hold optical block in fingers from its sides (not to touch lens itself) and move it to outward and inward with little force. Then plug it, power up, eject, place disc and check playback
    Sergeant:
  • 399 Answers
Turn off your DVD player. You do not want to risk electrical shock while working with it.---------------------Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.---------------Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.-----Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.---------Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. Things You’ll Need:
How to Open a DVD Door Without Turning on the Device--------You went to bed last night with that DVD you rented still resting in the player. Now you're ready to return the disk, but the machine won't power up, and you can't get the door to slide open. You can retrieve the DVD without breaking the machine----------
Find an object with a small point. A straightened paper clip is perfect for the task. Pins or needles are also an option.--------Find the small hole near the face of your DVD drive or the door. Many DVD players have this tiny hole on the door next to the eject button. This is the manual or emergency release point.--------Insert the point of your implement into the hole. Apply slight pressure to release the mechanism holding the door closed. Applying too much pressure could damage the machine, so start with a little and slowly add more until the unit opens the door. Retrieve your DVD.
  • 1,800 Answers
U ve to take it apart and check the stripped gear; oh before doing that plz make sure that after pressing eject button u r hearing some flickering noise.
force the tray out/in till get ti it place.
    Genius:
  • 1,239 Answers
HI WELCOME TO FIXYA ITS SIMPLE  change the area code in your DVD player setup.
    Genius:
  • 1,550 Answers
  • Foreign object are blocking disc drawer.
  • Stripped gear or other mechanical damage.
  • Gear timing is messed up.
  • The belt is damaged .
  • 734 Answers
Seems to be a dead spindle motor or controller
  • futureloginn
    futureloginn Dec 10, 2008
    Seems to be a dead spindle motor or controller.
    better buy a new.
    Thanks
    Sergeant:
    Champion:
  • 435 Answers
Hi, Do you mean there is no power to the unit ? If so, check if the fuse in the unit went off.
Does it have any disk already loaded into it? If the power is on and the deck is not opening, the disk might have got stuck into it. You can open the unit and release it.
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
The disktray automaticly opens and closed several times. When I put a cd in de tray the tray closed and opend without playing
Hi, when a disk tray automatically opens and closed several time, might be from the disk tray itself is jambed that's why it opening and closes by itself. You can open up the player and check if any thing in hooking it.
Also it might need to be replaced, the wheels inside the DVD player might be too weak to move in and out without moving automatically.
The way i see it, you might end up replacing the disk tray with a new one..
Have a nice day.
Feb 18, 2011 | Audio Players & Recorders
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
Region Settings
Turn Player On
Open The Disk Tray (Leave Open)
On Remote Control Press Stop
On Remote Control Press 1.3.6.9 and 0 (Zero)
Close Disk Tray
Power Off
or
Turn Player On
On Remote Control Press Clear
Close Disk Tray
Power Off
Jun 28, 2008 | Disney DTD1363-CAR 13" TV/DVD
Toshiba SD-K760 region codes.
I found this on another site, worked for me, hope it helps...
icon_minipost.gifRegion code hack posted by Stratos, April 30 2006:
1. Press the Open button on your remote control to open the drive tray
2. Press the 2403960 button on your remote control
3. Press the 1 button on your remote control to change the region to 1, 2 for region 2, and so on, or 9 for multi-region playback. New region number will appear on screen.
4. Press the Open button on your remote control to close the drive tray
5. Power off the DVD player
6. Power on the DVD player
Jan 17, 2008 | Toshiba SD-K760 DVD Player
Eject tray belt broke
Opening the DVD player tray is not as hard as you would think.
1. Remove three black screws holding the outer cover on the unit (located on rear of unit)
2. Carefully remove front panel trim by gently prying six clips (3 on top, 3 on bottom) away from unit and pulling panel away from unit.
3. Locate opening at the front of the DVD player that houses a larger white gear.
4. Using a finger, gently move gear until DVD tray begins to move outward.
5. Continue until DVD is fully ejected.
6. Try plugging the unit back into AC outlet and attempt to Open/Close the tray using the provided button on the Front Panel Circuit Board.
7. Reverse steps above to put unit back together.
Nov 27, 2007 | Sony SLV-D350P DVD Player/VCR
Disk Tray Will Not Open
Hmmmm, I see! Sometimes on my xbox the tray does not open. Maybe if you hit the top of your DVD Player a few times the disc tray may open. You must first click the button to open it then hit it on the top. If that doesn't work then sorry. From Jake @ www.Drama-King-Jake-2.piczo.com!
Oct 12, 2007 | Televison & Video
Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
