Question about Maytag MMV4205 Microwave Oven
Maytag microwave model#mmv500adb
Microwave stop working.. fuse check good . interlock switches. checked okay.. light works. keypad indicates time. no other keypad function works when pushed..
  • 1 more comment
  • mathnut Dec 26, 2007
    I heard a loud click then the microwave oven shut off completely. There is no response. It is dark. I tried resetting the safety breaker switch that controls oven and other appliances in the kitchen area but that did nothing to restart the microwave. Help!
  • Joannah Feb 09, 2008
    Our microwave worked fine one minute and then displayed "door" in the "time" window and the light will not turn off. The door is shutting perfectly fine. We can not punch anything into the key punch either???? Anyone have any ideas???????????????
  • Anonymous Mar 25, 2014
    how to fix interlock switch
  • Maytag Master
  • 9,098 Answers
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the hood fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Feb 19, 2007
Lite stays on,clock works, timer works, but keypad will not set to heat
It could be the pads themselves. The touch pads are notorious for going bad. The light staying on could be a bad door switch. Check there first. There are three switches in the door interlock assembly. One of them could be causing the unit not to reset so it can cook.
May 03, 2015 | Maytag Microwave Ovens
Doen't heat food
More information will be needed to solve this issue. Does the keypad work? What about the interior light or the turntable? Check the internal fuse, and the door interlock switches.
May 02, 2014 | GE XL1800 1100 Watts Microwave Oven
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No signal came on
  1. Make sure microwave is plugged in properly.
  2. Check that door closes completely and its latch is aligned.
  3. Check that interlock switch in door works properly (required for activating microwave).
  4. Replace a blown fuse if it's accessible, or contact a service technician.
    hope this helps you
Dec 30, 2009 | Maytag MMV4205 Microwave Oven
MMV5000ADW Maytag Microwave Keypad stops working. The light switches on and off when the door is operated and works fine. The time display is working. The keypad is non-responsive. Please help figure out...
How old is this unit? have you taken it apart?there was at one time a wiring issue with these units,depends on the age.other wise I'd say you have a bad touchpad it was another common issue with this unit. part number 56001263 in white runs around $80
Sep 27, 2009 | Maytag MMV5000 Microwave Oven
Model #MMV5100AAB built 01/2002 no power
Check the back panel for a breaker reset. If none, remove the case cover (pull the plug) and look for any blown fuses. If look ok, then check the interlock switch(es) for function when the door is closed. They are micro-switches and should make a distinct 'click' when operated. If you find a blown fuse, replace the high voltage diode in the magnetron power supply and replace the 'stirrer' (a fan-like device located under the sheet metal wave guide where the microwave energy enters the cooking cavity). It has a plastic bearing that can arc across inside it and short the energy out.
Sep 18, 2009 | Maytag MMV4205 Microwave Oven
Emerson model 8117w stop working all at once
This microwave has three door interlock switches and a fuse that are easily replaced by the consumer. Unplug the microwave. Remove the cover by unscrewing the 5 screws on the cover. Four are on the back, one on the lower right. One or more of the screws may be torx T15S (security)(bit available at hardware stores). As in all microwaves the capacitor should be discharged by shorting the cap terminals together. Note that the three switches are in a single black plastic carrier. Remove the two screws securing the carrier and the switches can be released by hand. Replace one at a time so as not to confuse the wiring which is push on spade terminals. Replace the fuse with a 20 amp 125v slow blow (radio shack). Do not plug in power until all the switches are reinstalled as a safety feature will cause the fuse to blow again. If fuse blows repeatedly it is most likely that all three interlock switches are not closing properly. Check to make sure that all switches are seated correctly in the black plastic switch carrier and that the 2 carrier screws are tight. Observe the switches as the door is closed. Replace switches and/or carrier as needed. While the cover is off you may want to clean off the fan and/or replace the bulb. Also check for proper seating of the control board connections.
Aug 13, 2009 | GE Microwave Ovens
Cookworks microwave not working
replace the fuse see if it blows again you can get those at radio shack 250 volt either 15 or 20 amp get 3 or 4 of em
Jul 29, 2009 | Microwave Ovens
Maytag MMV4205 Microwave Oven Logo
249 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
