Saya Punya Printer Canon IP 1980, printer sudah terkonek ke PC driver
sudah ok tapi ketika saya print tidak ada respon sama sekali saya cek
kabelnya bagus tidak ada masalah . kepada para sahabat saya minta
bantuannya dan solusinya ? ...
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord. 2. Press & hold the power button. 3. Connect the power cord WHILE holding the power button. 4. Keep on holding the power button for about 30 seconds. 5. Release the power button. The printer should be turned off. 6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Manual reset for canon pixma iP 1980 it easy and like resetting canon
ip 1880.If found problem in your printer canon iP 1980 maybe this
methode can be use. This reset manual be used to reset waste ink
counter in canon pixma iP 1980.
Here how :
Turn on your printer Canon Pixma iP1980
now Press and hold Resume button for two (2) minutes and then release Resume button.
Turn off the printer and turn on again, the Printer will back to normal again.
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
