Dented keyboard area...
I have an Asus M3000n laptop that has physical damage in the touchpad/spacebar area caused by a falling object. The laptop appears to funtion ok, but I would like to ''straighten out'' the depression caused by the accident. My question is; how do I take the laptop apart to get to the underside of the keyboard area?
I would also be interested in knowing how to go about getting a service manual for the laptop.
    Master:
  • 461 Answers
I could not locate a free service manual, but from my experience on DELL laptops it's more trouble than it would be worth to take it apart just for a dent. You'd be only risking further damage in the disassembly and possibly not be able to completely remove all signs of the dent anyway. Again I do not access to the service manual, but all laptops I've serviced requires removal of the hinge/control cover, antenna wires, display and keyboard just to be able to remove the palmrest.
Posted on Dec 07, 2008
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
Replacing the Cmos battery on my asus note book M3000N model M3N
http://www.laptop-dvd-drivers.com/asus-m3n-laptop-motherboard-p-1549.html
Click on the left view, use your mouse cursor, and magnify the black object. (Maxell)
It has a Red wire, and a Black wire ending in a small White plug.
The black object is just a type of plastic bag, essentially. There is a CR2032 battery inside it. The small white plug coming from the battery's wires plugs into the motherboard.
The Left view is a view of the Bottom. The RTC battery is on the bottom of the motherboard.
So is the Processor.
[RTC = Real Time Clock. Newer nomenclature for the CMOS battery]
Another view of the RTC Battery,
http://www.pchub.com/uph/model/0--10040-3/M3000N-M3N--parts.html?ps=20&type=0
Bottom of page. (Maxell CR2032WK)
No exact Service Manual. Use the following info to disassemble the laptop with. USE an ESD wrist strap, and connect it's alligator clip to a good ground source. Or you can use the laptop for an expensive paperweight.
Regards,
joecoolvette
1) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-asus
2) http://www.insidemylaptop.com/category/2-asus-laptops/
Oct 11, 2012 | Acer Notebook
Loose all motherboard settings when switching off,could it be the bios battery,if so where is it located on the m3000n.
Could be the CMOS battery. I couldn't find any reference at ASUS.
Locations of these vary from model to model but, in most cases, the battery are found underneath the keyboard. Some manufacturers locate the cells in odd places like underneath a mouse ball, touch pad or in the screen frame housing.
Some laptops might have multiple batteries and not all are CR232s
Aug 14, 2010 | ASUS M3000N Notebook
I have a asus m3000n laptop..i'm missing the hd connector..so far-no where sell that part...where can you get parts...asus store stop selling most of the parts.
You can usually find them on ebay. Try searching for an asus m300n hard drive caddy.
The caddy part is the key ;)
Jan 27, 2010 | ASUS M3000N Notebook
Keyboard Spacebar does not work
you will change the space bar button
Jan 10, 2010 | Dell F3534 Touchpad
Problemwith spacebar
If you take all those tiny screws out of the bottom of the keyboard you'll see a circuitboard with three copper "design" spots(usually 3) under the spacebar..........the ones NOT in the center of the spacebar are dirty. You could use some alcohol or acetone to clean the outside "designs".....(warning) Acetone will damage plastic!!!!!!!!
there are a lot of rubber caps that WILL fall out of place when you turn it over) (the actual keys could fall out too) (Be careful when you take off the bottom of the keyboard!!!!) Clean the ones that align with the SPACEBAR!!!! Dont touch or clean anything else that wasn't working....... Gently place the bottom back on and screw down the bottom cover with a cross pattern.....(left>right...top>bottom).....If this dosn't work....the best part is that a new keyboard........is fairly cheap....mtg
Apr 14, 2009 | Computers & Internet
Touchpad & Keyboard unresponsive
please replaced the laptop ,other option u r put the button & clean the button
Mar 16, 2009 | Acer Aspire 5720 Notebook
Broken Keyboard
Try These
http://www.laptoprepairparts.com/html/searchbrandresults.asp?mfg=asus
http://www.pchub.com/uph/brand/-16/Asus-part-spare.html
There are'nt alot of ASUS parts dealers so goodluck m your best bet is to reaplce the keyboard though
Cheers
Aug 23, 2008 | Computers & Internet
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
