Question about Xerox Phaser 7400DN Laser Printer
Print jobs are not getting queued.
It is a Xerox 7300N machine and one of the guys having two major problems. firstly, print jobs are not queuing. Secondly, Color registration problems.
    Novelist:
  • 208 Answers
This is late but most likely the IP address is set to DHCP or auto and the printer is changing the IP address.
You need to set it to manual, and set the IP address static.
Those machines will change the IP address by itself.
Sometime even when you have set it manually it will change back to auto.
Posted on Dec 04, 2007
Gets queued to print and gets error f42b.
corrupt print job. download the latest KX6 driver from kyocera's website. there are many settings in that driver to help with errors but usually driver upgrade helps. the firmware on the machine needs to be at its latest level as well.
Sep 19, 2014 | Kyocera Office Equipment & Supplies
I am trying to print from my netbook using an hp printer. i am getting an error message saying that the print queue is full.
Yes, printer won't print if print queue is full. The fact is you are lucky your printer is giving you this message. Most printers, when queue is full, will just remain silent and leave you wandering what in the world has gone wrong.
Solution is to clear the print queue. See, when you send to print and you send another when the previous hasn't printed, they queue up. Now if for any reason the first fails to print, all others will just remain queued up but will not print until you clear the print jobs queued up.
To do, this go to start/control panel/printers. Right click on printer icon and select open. The respective print queue box appears. It should have all of the print jobs listed there in the box. On the menu bar click on printer and select "Cancel all documents." A box appears asking you to confirm if you want to cancel, answer yes. Then try to print again. If it still fails to print restart your PC and try to print again.
Dec 06, 2009 | Office Equipment & Supplies
Delayed printing
Your problem lies in the vista software. This is a common problem where Vista cannot often read the software drivers quick enough or are not compatible which makes it not work properly. My advice would be to get rid of vista and go back to XP, it was much more compatible with everything. Problem could also be in the cable. Make sure they are plugged in nice and snug. Cheers.
Oct 02, 2009 | Computers & Internet
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Epson Stylus C88 puts the job in the queu and doesn't print
Have you tried running an independent printer check - see
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
If the printer prints the test page OK, it means the problem is with the computer. If it were a PC, I would uninstall, reboot and then re-install the driver software. Maybe this will work with a Mac?
Feb 19, 2009 | Epson CX8400 All-In-One InkJet Printer
Wont load paper
Please check the following items:
Check item 1:
The cable may not be securely connected between a printer and a computer, or be about to be unconnected.
Check that the cable is securely inserted into the ports of the printer and the computer respectively.
If a USB hub is used, connect the printer and the computer directly.
Check item 2:
Print jobs may be queued.
Delete the print jobs queued in the computer. How to delete the accumulated and queued documents in the computer (Windows)
Check item 3:
The computer settings may not be corrected.
Check the computer settings. How to confirm the computer settings (Windows)
Jan 14, 2008 | Canon PIXMA iP90 Mobile Printer
Paper wont load
Check item 1:
Check item 2:
Check item 3:
Xerox Phaser 7400DN Laser Printer Logo
260 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
