Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I have an older Frigidaire oven but digital (push button) cannot figure out how to make the self clean work, it didn't come with a manual says the model is MWSR33W-5 and I cannot find this on the net....can you help?
  • 1073 Answers
SOURCE: Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Posted on Apr 12, 2008
SOURCE: I have a Frigidaire 30" self cleaning oven that is a stand alone...the oven stopped working this past weekend
have your electronic timer sent for repairs, go on internet at ApplianceTomers.com
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
Posted on Dec 09, 2008
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Posted on Feb 23, 2009
localwonder
  • 6784 Answers
SOURCE: Oven door will not lock to clean
hi, these two codes together are signaling a EOC failure. the electronic oven control has failed and you will need to replace the EOC/clock. it is unable to initiate any commands because, it in a frozen state.
You can try to reset this control by unplugging the entire unit for 5 minutes. if the control continues to not reaspond to your commands, replace the EOC.
please rate and god bless:)
Posted on Apr 16, 2009
How do I operate my self-cleaning oven..no manual..
Thank you for your post, Pattie Cromie!
I see that you would like to operate self-clean on your Frigidaire range and you do not have the manual. Typically, to start self-clean you would need to push the button labeled "Self-clean" and make sure there is nothing inside the oven before starting a self-clean cycle. Also before starting self-clean close the door because of the temperatures that are created within the oven the door needs to be closed and locked. I hope this has been beneficial. -Matt
Oct 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have a self-cleaning older Frigidaire oven RE36BNL*2 and have had several power interuptions. I went to use the oven and the timer and oven controls won't work. There is an OFF displayed and it...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have an older model gibson self cleaning oven. How do I start the self cleaning process. No manual. Thanks.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Sep 25, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I am trying to clean the oven,
you can try and hold the door closed by hand and push the self cleaning button.and it might work
if that does nothing for you there might be a problem with the door switch.
the other likely problem is a bad clock timer/main control panel
Jan 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Self clean results in f9 and beeping
heatman101
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 14, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electri clean selfcleaning feature
It locks automatically. You can download the manual from Frigidaire here (as I just discovered while trying to figure out how to use the self-cleaning feature :) ): http://www.frigidaire.com/support/manuals.asp?NewSearch=New+Search
You don't need to type in the whole model number. For example, if the model number (found in the upper left when you open the oven door) is RSE37BAW*4, you only need to enter RSE37BA.
Apr 27, 2008 | Frigidaire Ovens
Frigidaire non-digital (old) Caprice top electric oven not working
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
Jan 21, 2008 | Frigidaire 27 in. Electric Double...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
62 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
