Question about Ranger Communications RCI-6900F-25 CB Radio
No transmit sound comes thru speake but radio has no talk back
Ranger tr-696fd1 moble
  • 463 Answers
Are you trying to say that the radio has talkback but you can't hear it? And that's a bad thing? All talkback does is increase the likelyhood you're going to squeal when using high power. Or with that high-power eye-legal leenyer.
Posted on Mar 24, 2009
    Scholar:
  • 67 Answers
Do you have it set on PA (public address)
Posted on Dec 27, 2008
When the mike is keyed to TR my audio comes thru the speaker. Cobra 29 LTD Classic. Best Regards Jim
If your voice is coming through the speaker when you transmit, it means you have talkback installed. If you don't like it, take it to a reputable CB shop and ask them to remove it.
Aug 06, 2010 | Cobra 29 LTD CB Radio
Voice recognition on motorola t5500
That means that it will Transmit, like pressing the "Talk" button, BUT ONLY when it hears the "Voice" it was "Trained" on. So this is so No-one else could use this unit. With this method. You "Identify" yourself, and after that every-time you speak, the Transmitter is keyed, and the channel is opened and the voice sent, when you stop talking,it goes back to receive, again. Some are less sophisticated, in that they are really a "Sound Switch" and when the unit "Hears" a "Voice" it, switches OFF receive, and ON the transmitter, and Transmits the audio out.
Apr 15, 2010 | Motorola Talkabout T5500 (7 Channels)...
Cannot transmit
You have to tern of function scrambler or CTCSS privacy code. To make this use the menu
Apr 11, 2010 | Motorola Walkie Talkie 2-Way Radio
The power is on, however, when I use the mic and speak the "needle" doesn't move, I have tried different mics. Also, the sound coming from the radio is also very soft.
When you say the sound coming from the radio is very soft, are you talking about talk back? if so, you want that soft. If you are talking about reception then just get an external speaker.
If the radio is working, and transmitting ok, the meter is not important.
You may want to get an external meter to make sure SWR's are good.
If it is not transmitting at all, there could be a real problem and the radio needs a tech.
Aug 14, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
My ranger 2950 will receive but will not transmit, also where can i get a 6 pin mike for this same radio ?
check tr 51 (Q 51) the sb754 on the back side mounting of the radio.. the center pin (collector) of this modulator ic should not be 13 volts. my bet is that it is.. this test is done in am mode.. not sideband.
depending on you carrier setiing it should be between 3 -8 volts any higher in am mode and my bet is that its bad... much more common than the finals in this radio. good luck Rick
Dec 13, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
No cb channels no audio no recive
If you have no channel display or CB operation, it sounds like a blown voltage regulator that supplies power to the CB PLL circuit.
Sep 14, 2008 | Ranger TR-696F SSB CB Radio
SSB radio
If you are using the radio on a boat, then no, the grounding does not matter that much. However, an SSB transceiver would be hassle to install on a boat because of the amount of power they use to transmit. If the transmission is bad, try using the radio's internal tuner instead of the separate tuner. This may help improve the quality of transmit, however, some radios have a tough time clarifying incoming and outgoing signals and create a garbled sound when it receives a signal or when it transmits. If that doesn't work, then you can try grounding. But if you want a radio that doesn't require all this nonsense tning, you might want to think about investing in a Yaesu. They are pricey, but are one of the best HAM radios.
Sep 04, 2008 | Ranger TR-696F SSB CB Radio
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Ranger Communications RCI-6900F-25 CB Radio Logo
207 people viewed this question
Top Ranger Radio Communications Experts
Jon Piercy
perdue40
TekkiDave
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
